Door Trigger Problem with my Car Alarm System
mohsen2018
Posted: June 05, 2018 at 6:21 PM / IP Logged Link to Post Post Reply Quote mohsen2018
all alarm systems have a built in auto arme mode , when press the unlock key and no body get in the car the system will lock it self after 30 seconds .
This function is based on the door trigger signal , so when opening the door , a negative (or positive) signal is received on the alarm (blue wire) from the door trigger .
But my car and the majority of peugeot cars is sending this negative signal when just pressing the unlock key from remote !!! and the ceiling light is ON Without opening the door . So the auto arm mode will not working because the alarm has received the signal !!
Please help me guys to solve this problem , i want to get a negative signal on the alarm when i open the door , not when pressing the unlock key remote .
Maybe a relay circuit or another trick will solve this problem
Mohsen
dswift
Copper - Posts: 396
Posted: June 19, 2018 at 6:32 PM / IP Logged Link to Post Post Reply Quote dswift
You're describing "Auto Relock". This might be an OEM feature as most manufacturers offer this feature. What system is installed in your vehicle and what feature are you looking for? I'm not understanding your question.
"dont ground out!"
catback
Silver - Posts: 703
Posted: June 23, 2018 at 9:03 AM / IP Logged Link to Post Post Reply Quote catback
You need to disconnect the dome supervision or connect it properly and not use the often used shortcut of tying it to the door trigger.
Wednesday, May 29, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
