Code Alarm CATX4 Won't Unlock Doors, 2011 Chevy Cruze
dfgdsfgh
Posted: June 09, 2018 at 1:21 PM / IP Logged Link to Post Post Reply Quote dfgdsfgh
chevy cruze 2011
Hood and trunk are closed.
I have to spam the unlock for minutes (one time took 10 minutes) to get it to unlock.
It locks with one press of lock.
It starts my car up with the press of the startup button.
The three press to open trunk no longer works (same button as unlock)
I have replaced:
1. Battery in fob
2. Battery in car (have to replace it yearly anyway in arizona)
3. code alarm Sensor
4. door lock actuators (they had other issues, just mentioning cause they new)
I have an ebay fob being sent to me.
However, in the event that fails to unlock the car properly, what are some other suggestions you guys have that could be the cause?
joshuajoshua
Posted: August 13, 2018 at 9:58 PM / IP Logged Link to Post Post Reply Quote joshuajoshua
What was the solution?
I have the same problem with my Toyota Tundra...
Won’t unlock, just lock and start...
Had it a year, and it just started acting up this week.
I think it’s a fuse...
Josh
silvercivicsir
Copper - Posts: 409
Posted: August 23, 2018 at 3:14 PM / IP Logged Link to Post Post Reply Quote silvercivicsir
what bypass module did you use? might want to reset the bypass, and program it for dbl pulse unlock.
silvercivicsir
Copper - Posts: 409
Posted: August 23, 2018 at 3:15 PM / IP Logged Link to Post Post Reply Quote silvercivicsir
or could try adding disarm to the door pin wire to wake up the BCM.
silvercivicsir
Copper - Posts: 409
Posted: August 23, 2018 at 3:16 PM / IP Logged Link to Post Post Reply Quote silvercivicsir
oh as for the trunk, it's Press and HOLD unlock for 3 seconds.
beegbie
Copper - Posts: 341
Posted: August 24, 2018 at 8:58 PM / IP Logged Link to Post Post Reply Quote beegbie
Does the led on the remote come on when pressing unlock?
joshuajoshua
Posted: August 25, 2018 at 6:34 PM / IP Logged Link to Post Post Reply Quote joshuajoshua
No trunk, it’s a tundra.
joshuajoshua
Posted: August 25, 2018 at 6:35 PM / IP Logged Link to Post Post Reply Quote joshuajoshua
LED does come on, I even tried my back up clicker.
joshuajoshua
Posted: August 25, 2018 at 6:37 PM / IP Logged Link to Post Post Reply Quote joshuajoshua
Gotta get back in there and figure out which bypass mod was.
It all worked fine for a year, until two weeks ago.
The system clicks, but it does not unlock the doors.
Trying to find that 4th fuse...
Sunday, June 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
