Momentary Reversible Motor Control with Relays?
redrelay
Posted: November 01, 2018 at 1:49 PM / IP Logged Link to Post Post Reply Quote redrelay
I have a power-folding motor that I want to control from a 2018 Honda. I'm not sure what the amp draw or other characteristics are (it's an OEM part without spec sheet).
On the dashboard is a "blank" where I'm hoping to install the switch. The total size of the piece is 1.25" x 13/16" but it gets narrower in back and thus any switch can only be ~0.75" x 0.75". I was originally planning to use a "(On)-Off-(On)" DPDT toggle with a cross-over pattern to allow reversible control but seems that any switch that fits in this small space likely doesn't have enough DC amp rating for an inductive motor load.
Questions:
1.) How much current would you expect a power-folding mirror to draw?
2.) What type of rating should I be looking for on a switch for an inductive load?
3.) Any suggested circuit design? I want the motor to run either forward or reverse when the toggle switch is either momentarily flipped up or down. I'm thinking I might need to use relays?
Platinum - Posts: 13,676
Posted: November 01, 2018 at 8:44 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Thursday, June 6, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
