2013 Honda Civic, Viper 4706V and Idatalink ADS-ALCA
crackjack135
Member - Posts: 15
Posted: February 06, 2019 at 3:51 PM / IP Logged Link to Post Post Reply Quote crackjack135
Hey,
I am trying to install a viper 4706v with Idatalink ads-al ca Data Bypass on a Honda Civic 2013. This is a 4-door, automatic car. Can you provide a wiring schematic and installation instructions, please? If it helps, I have the data mode cable for both units. Thanks in advance guys.
the12volt
Administrator - Posts: 3,955
Posted: February 06, 2019 at 4:00 PM / IP Logged Link to Post Post Reply Quote the12volt
crackjack135
Member - Posts: 15
Posted: February 06, 2019 at 7:56 PM / IP Logged Link to Post Post Reply Quote crackjack135
I saw that post, i was just curious if anyone had where the wires on the rs and bypass unit got hooked up to on the car
crackjack135
Member - Posts: 15
Posted: February 09, 2019 at 8:11 AM / IP Logged Link to Post Post Reply Quote crackjack135
So i have almost everything labeled and ready to install but i have a couple questions.
1) The idatalink has CANH and CANL, does that get connected to CAN HIGH/LOW or CAN HIGH2/LOW2? I think its high2/low2 but not sure
2)is key data in idatalink the IMMO data?
3)for the Viper 4706v im using if im doing d2d, for the trunk release button do i have to connect the (-)200mA TRUNK RELEASE OUTPUT to Trunk Release Motor green 5 wire     dash fuse box, green 44 pin plug (B), pin 9
4) since im using d2d do i need to connect the door lock connector from the viper to the car
crackjack135
Member - Posts: 15
Posted: February 10, 2019 at 4:43 PM / IP Logged Link to Post Post Reply Quote crackjack135
As i stated i have an automatic 2013 honda civic sedan with a viper 4806v and idatalink alca. I finished wiring everything up today after using the wiring diragrams on the site here, and ended up having to program it out of manual mode and add a ground (parking lights flashed 7 times and then 8 times). once i finished that the remote start button would work and the engine would crank but wont turn over. when i press the lock and unlock buttons, the horn beeps once and twice accordingly and shows the correct symbol on the remote but doesn't lock or unlock. the same thing goes for the trunk release, the symbol changes and says the trunk is open but the trunk still stays locked.
silvercivicsir
Copper - Posts: 409
Posted: February 10, 2019 at 11:19 PM / IP Logged Link to Post Post Reply Quote silvercivicsir
did you follow the diagram for the ALCA ? get the can h/l / immo / ign cut, at the transponder plug? This is a simple car, and the bypass will do all functions. Tach / locks / trunk.
As for the viper, did you ground the blk/white? and learn Tach?
crackjack135
Member - Posts: 15
Posted: February 11, 2019 at 10:16 AM / IP Logged Link to Post Post Reply Quote crackjack135
Yeah i followed the bypass diagram.
Can H brown /red to pink
Can L brown/yellow to blue
Key data orange/black to light green
Ignition white/black to yellow connector side
Ignition white/red to yellow vehicle side
Pink ignition input spliced to ignition white/red vehicle side.
All these connection are on the same plug
I also only hooked up the solid black lines, and i did not hook up the red solid or black dashed lines.
silvercivicsir
Copper - Posts: 409
Posted: February 11, 2019 at 11:13 AM / IP Logged Link to Post Post Reply Quote silvercivicsir
did the module program correctly? (ie the green light came on) when you turned the key to program it? [did the diagram pin#'s match the wire colors]?
just for fun, put the key in the ignition, and try remote starting it.
crackjack135
Member - Posts: 15
Posted: February 11, 2019 at 3:46 PM / IP Logged Link to Post Post Reply Quote crackjack135
Yes the green light was on during programming, and yes the pin matched the wire colors, but the connector was gray not white.
So i put the key in the ignition and turned it on with the remote start and it worked. The lock, unlock, and trunk release still doesnt work though.
silvercivicsir
Copper - Posts: 409
Posted: February 11, 2019 at 5:32 PM / IP Logged Link to Post Post Reply Quote silvercivicsir
So the module programmed correctly.. ( Green light when you turned it on) and the remote start wiring is correct (starts the car with the key).
When you initially programmed the bypass for the honda civic, you selected "DBI" mode? When you try and remote start the car, does the bypass turn on? if it doesn't it could either be the wrong data mode was selected, or you might have a bad DBI port on the viper brain. You plugged the red dbi cable into the viper? You could also try hard wiring the bypass.
Page of 3
Saturday, June 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
