2011 Subaru Outback, Compustar CM900-AS, ADS Blade-AL
ukie219
Posted: January 08, 2020 at 11:02 AM / IP Logged Link to Post Post Reply Quote ukie219
The doors do not lock or unlock with the new fob. I have not landed individual wires for the door locks (from CN3) because I assumed that the Blade would be communicating through the Can bus. Just looking to know for sure that I still have to land those additional wires. Thank you.
mgoetz74
Silver - Posts: 424
Posted: January 08, 2020 at 11:26 AM / IP Logged Link to Post Post Reply Quote mgoetz74
https://images.idatalink.com/corporate/Content/Manuals/DL-SUB3/COM-BLADE-AL(DL)-SUB3-EN_20190726.pdf
you have to use a relay and wire the door lock special on Subaru.
ukie219
Posted: January 08, 2020 at 6:12 PM / IP Logged Link to Post Post Reply Quote ukie219
Thank you for your reply, unfortunately I followed that diagram and this is why I'm here. I'm not 100% clear whether the blade is using the can bus for the door locks or do I have to land the actual wires from Cn3.
Platinum - Posts: 7,791
Posted: January 09, 2020 at 7:41 AM / IP Logged Link to Post Post Reply Quote kreg357
There is no need to connect the R/S CN3 wires to the Outbacks Lock / Unlock wires. The Blade-AL will handle the locks and Factory Alarm for you via it's connections to the car. You will need the relay shown in the Type 3 Install diagram in place and wired correctly to the Keyless wire.
ukie219
Posted: January 09, 2020 at 11:44 AM / IP Logged Link to Post Post Reply Quote ukie219
Thank you for spelling it out for me. Apparently I used a bad relay initially. After changing it everything works correctly. Again, thank you kindly.
Saturday, June 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
