2007 Ford Mustang, Viper 5706V Alarm
1rickster1
Member - Posts: 8
Posted: April 08, 2023 at 7:34 PM / IP Logged Link to Post Post Reply Quote 1rickster1
Hi All,
I'm installing a Viper 5706V on a 2007 Mustang V6 and would like to know if I need to add a 2 ignition to my install in order to get the remote start working. The vehicle OEM wiring only has ignition 1 and the Viper remote start module has the factory menu option listed as "Ignition 2" under the Flex Relay Function. Thanks in advance!
Rick
Platinum - Posts: 7,790
Posted: April 08, 2023 at 8:38 PM / IP Logged Link to Post Post Reply Quote kreg357
Your 2007 Mustang has only one Ignition wire. As such the Viper IGN2 (Pink/White) wire will be unused.
What are you using for the transponder bypass?
1rickster1
Member - Posts: 8
Posted: April 10, 2023 at 8:21 PM / IP Logged Link to Post Post Reply Quote 1rickster1
I'm using the idatalink ALCA. I can hear the electronics engage but no engine crank over when I hit the remote start.
Rick
Posted: April 10, 2023 at 9:53 PM / IP Logged Link to Post Post Reply Quote kreg357
A few thoughts...
What was the firmware flashed on to the ADS-ALCA?
Are you going D2D or W2W between the Viper and the ADS-ALCA?
Did the ADS-ALCA program as per the Programming Instructions?
It might help if you listed all the Viper connections, especially the 10 Pin Main Ignition harness ( the Red and Red/Black must be connected to +12V Constant).
Below is a Viper wire list to use.
Viper 5706
Main Harness, 6-pin connector
1 RED (+)12VDC CONSTANT INPUT
2 BLACK (-) CHASSIS GROUND
3 BROWN (+) SIREN OUTPUT
4 WHITE/BROWN PARKING LIGHT ISOLATION WIRE - PIN 87a of onboard relay
5 WHITE PARKING LIGHT OUTPUT
6 ORANGE (-) 500mA GROUND WHEN ARMED OUTPUT
Door Lock, 3-pin connector
1 BLUE (-) 500mA UNLOCK OUTPUT
2 EMPTY NOT USED
3 GREEN (-) 500mA LOCK OUTPUT
Remote Start, 10-pin heavy gauge connector
1 NC No Connection
2 RED/BLACK (+) FUSED 12V ACCESSORY/STARTER INPUT
3 PINK/BLACK (+) FLEX RELAY INPUT 87A key side (if required) of FLEX RELAY
4 PINK/WHITE (+) IGNITION 2 / FLEX RELAY OUTPUT
5 RED (+) FUSED 12V IGNITION 1 INPUT
6 GREEN (+) STARTER INPUT (KEY SIDE OF THE STARTER KILL)
7 VIOLET (+) STARTER OUTPUT (CAR SIDE OF THE STARTER KILL)
8 ORANGE (+) ACCESSORY OUTPUT
9 RED/WHITE (+) FUSED 12V IGNITION 2 / FLEX RELAY INPUT 87
10 PINK (+) IGNITION 1 INPUT/OUTPUT
Auxiliary/Shutdown/Trigger Harness, 24-pin connector
1 PNK/WHITE (-) 200mA Ignition 2/Flex OUTPUT
2 BLUE/WHITE (-) 200mA 2ND STATUS /REAR DEFOGGER OUTPUT
3 RED/WHITE (-) 200mA TRUNK RELEASE OUTPUT
4 BLACK/YELLOW (-) 200mA DOME LIGHT OUTPUT
5 DARK BLUE (-) 200mA STATUS OUTPUT
6 WHITE/BLACK (-) 200mA AUX 3 OUTPUT
7 WHITE/VIOLET (-) 200mA AUX 1 OUTPUT
8 ORANGE/BLACK (-) 200mA AUX 4 OUTPUT
9 GRAY (-) HOOD PIN INPUT (NC OR NO)
10 BLUE (-) TRUNK PIN/INSTANT TRIGGER INPUT (N/C OR N/O)
11 WHITE/BLUE ACTIVATION INPUT
12 VIOLET/WHITE* TACHOMETER INPUT
13 BLACK/WHITE** (-) NEUTRAL SAFETY /PARKING BRAKE INPUT
14 GREEN/BLACK (-) 200mA FACTORY ALARM DISARM OUTPUT
15 GREEN* (-) DOOR INPUT
16 BROWN/BLACK (-) 200mA HORN HONK OUTPUT
17 PINK (-) 200mA IGNITION 1 OUTPUT
18 VIOLET* (+) DOOR INPUT
19 VIOLET/BLACK (-) 200mA AUX 2 OUTPUT
20 BROWN (+) BRAKE SHUTDOWN INPUT
21 VIOLET/YELLOW (-) 200mA STARTER OUTPUT
22 GRAY/BLACK (-) DIESEL WAIT TO START INPUT
23 ORANGE (-) 200mA ACCESSORY OUTPUT
24 GREEN/WHITE (-) 200mA FACTORY ALARM ARM OUTPUT
1rickster1
Member - Posts: 8
Posted: April 11, 2023 at 1:30 PM / IP Logged Link to Post Post Reply Quote 1rickster1
ADS-AL(TB)-FM2 v3.22
D2D (Also noticed no led flashing during remote start)
Yes and used KLON since I only have one key
Viper 5706
1 RED (+)12VDC CONSTANT INPUT ==> (LIGHT GREEN/PURPLE (+)@ IGNITION SWITCH HARNESS)
2 BLACK (-) CHASSIS GROUND ==> (Chassis Ground)
3 BROWN (+) SIREN OUTPUT ==> (To siren +)
4 WHITE/BROWN PARKING LIGHT ISOLATION WIRE - PIN 87a of onboard relay ==> (NC)
5 WHITE PARKING LIGHT OUTPUT ==>(BLACK/LIGHT GREEN (-)@ SJB, BLUE 52 Pin Plug, Pin 31 )
6 ORANGE (-) 500mA GROUND WHEN ARMED OUTPUT==> (NC)
1 BLUE (-) 500mA UNLOCK OUTPUT==> ( DARK BLUE/LIGHT GREEN (-) @ SJB, BLACK 26 Pin Plug, Pin 1)
2 EMPTY NOT USED
3 GREEN (-) 500mA LOCK OUTPUT ==>(WHITE/PURPLE (-) @ SJB, BLACK 26 pin Plug, Pin 3)
1 NC No Connection
2 RED/BLACK (+) FUSED 12V ACCESSORY/STARTER INPUT ==> (LIGHT GREEN/PURPLE (+)@ IGNITION SWITCH HARNESS)
3 PINK/BLACK (+) FLEX RELAY INPUT 87A key side (if required) of FLEX RELAY ==>(NC)
4 PINK/WHITE (+) IGNITION 2 / FLEX RELAY OUTPUT ==>(NC)
5 RED (+) FUSED 12V IGNITION 1 INPUT ==>(LIGHT GREEN/PURPLE (+)@ IGNITION SWITCH HARNESS)
6 GREEN (+) STARTER INPUT (KEY SIDE OF THE STARTER KILL) ==> (DARK GREEN (+) Key Side) @ IGNITION SWITCH HARNESS
7 VIOLET (+) STARTER OUTPUT (CAR SIDE OF THE STARTER KILL) ==> (DARK GREEN (+) Starter Side) @ IGNITION SWITCH HARNESS
8 ORANGE (+) ACCESSORY OUTPUT ==> (BLACK/PINK (+) @ IGNITION SWITCH HARNESS )
9 RED/WHITE (+) FUSED 12V IGNITION 2 / FLEX RELAY INPUT 87 ==>(NC)
10 PINK (+) IGNITION 1 INPUT/OUTPUT ==> (WHITE/YELLOW (+) @ IGNITION SWITCH HARNESS)
1 PNK/WHITE (-) 200mA Ignition 2/Flex OUTPUT ==>(NC)
2 BLUE/WHITE (-) 200mA 2ND STATUS /REAR DEFOGGER OUTPUT ==>(NC)
3 RED/WHITE (-) 200mA TRUNK RELEASE OUTPUT ==>(WHITE/PURPLE (-) @ SJB, BLACK 52 Pin Plug, Pin 13)
4 BLACK/YELLOW (-) 200mA DOME LIGHT OUTPUT==> (NC)
5 DARK BLUE (-) 200mA STATUS OUTPUT ==> (NC)
6 WHITE/BLACK (-) 200mA AUX 3 OUTPUT ==>(NC)
7 WHITE/VIOLET (-) 200mA AUX 1 OUTPUT==> (NC)
8 ORANGE/BLACK (-) 200mA AUX 4 OUTPUT ==>(NC)
9 GRAY (-) HOOD PIN INPUT ==>(Connected to pin switch installed at hood)
10 BLUE (-) TRUNK PIN/INSTANT TRIGGER INPUT ==>(NC)
11 WHITE/BLUE ACTIVATION INPUT ==>(NC)
12 VIOLET/WHITE* TACHOMETER INPUT ==>( PINK/WHITE @ IGNITON COIL)
13 BLACK/WHITE** (-) NEUTRAL SAFETY /PARKING BRAKE INPUT ==> RED/YELLOW @ SJB, GRAY 26 Pin Plug
14 GREEN/BLACK (-) 200mA FACTORY ALARM DISARM OUTPUT ==>(LIGHT BLUE/BLACK (-)@ SJB, BLACK 26 Pin Plug, Pin 16)
15 GREEN* (-) DOOR INPUT ==> (LIGHT GREEN/YELLOW (-) @ passenger kick panel, using dome lamp wire)
16 BROWN/BLACK (-) 200mA HORN HONK OUTPUT ==> (NC)
17 PINK (-) 200mA IGNITION 1 OUTPUT ==> (NC)
18 VIOLET* (+) DOOR INPUT ==> (NC)
19 VIOLET/BLACK (-) 200mA AUX 2 OUTPUT ==> (NC)
20 BROWN (+) BRAKE SHUTDOWN INPUT ==>(LIGHT GREEN (+) @ Brake Pedal)
21 VIOLET/YELLOW (-) 200mA STARTER OUTPUT ==>(NC)
22 GRAY/BLACK (-) DIESEL WAIT TO START INPUT ==>(NC)
23 ORANGE (-) 200mA ACCESSORY OUTPUT ==>(NC)
24 GREEN/WHITE (-) 200mA FACTORY ALARM ARM OUTPUT==> (NC)
Rick
Posted: April 11, 2023 at 4:46 PM / IP Logged Link to Post Post Reply Quote kreg357
Looks like the main issue is the firmware on the ADS-ALCA. If you want to go D2D you must use the DBI flavor of FM2 firmware. Refresh and reprogram, then see what happens.
1rickster1
Member - Posts: 8
Posted: April 11, 2023 at 5:27 PM / IP Logged Link to Post Post Reply Quote 1rickster1
Thanks! I'll try that this coming weekend.
Rick
1rickster1
Member - Posts: 8
Posted: April 16, 2023 at 8:18 PM / IP Logged Link to Post Post Reply Quote 1rickster1
Hi again,
Flashed module with DBI flavor of firmware but and reprogrammed successfully. Still not working though. I can hear the electronics engage but nothing cranks. I also checked the violet wire on the R/S heavy harness during remote start and it shows +12 volts but only for a couple of seconds then goes to 0.
Rick
Posted: April 16, 2023 at 9:05 PM / IP Logged Link to Post Post Reply Quote kreg357
First thought, as not mentioned previously...
Does the Mustang have a Manual Transmission? - Clutch Bypass
It shouldn't attempt a R/S ( bring up IGN or put +12V on the Violet Starter wire ) if you are in M/T Mode or the Parking Brake isn't on...
Any Parking Light codes flashed after a failed R/S? You might have to do the "Remote Start Shutdown/Startup Diagnostics" procedure to get the error code.
1rickster1
Member - Posts: 8
Posted: April 16, 2023 at 9:16 PM / IP Logged Link to Post Post Reply Quote 1rickster1
"Does the Mustang have a Manual Transmission? - Clutch Bypass"
Its an automatic and have switched the feature to automatic.
"It shouldn't attempt a R/S ( bring up IGN or put +12V on the Violet Starter wire ) if you are in M/T Mode or the Parking Brake isn't on..."
Parking brake on.
"Any Parking Light codes flashed after a failed R/S? You might have to do the "Remote Start Shutdown/Startup Diagnostics" procedure to get the error code."
None. I'm stumped.
Rick
Monday, June 3, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
