2013 Honda CR-V, Crimestopper RS3-G2, PKALL, Not Working
paradoxum
Posted: December 01, 2025 at 1:01 PM / IP Logged Link to Post Post Reply Quote paradoxum
Hi All,
Need some help troubleshooting this remote starter setup. It's been working problem free till it got cold. The main symptoms include no response to the remotes and that the LED in the antenna for the RS does not light up. I've confirmed 12v and good ground to the RS unit and the PKALL. Hood latch is not grounded. The RS is responsive when I attempt to enter programming mode by pressing the valet switch 4 times - parking lights blink. The LED on the PKALL does not light up at all (that I have seen so far). PKALL is connected non-D2D. Am I correct in assuming that the RS should blink errors with it's antenna LED even if the PKALL is dead?
Monday, February 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
