96 jeep grand cherokee door locks
salsosa12
Member - Posts: 7
Posted: August 26, 2003 at 11:18 AM / IP Logged
I Installed an alarm in a 96 jeep grand cherokee and i am having problems with the doors looks. If anyone could help me with this by sending a diagram or picture or any information would help.
Thank You
brianh
Silver - Posts: 518
Posted: August 26, 2003 at 3:27 PM / IP Logged
Alright, The door locks in this vehicle are the 5 wire type. You will need to go to the door lock section of this site and look up the 5 wire type door lock system. The wires you will need will be in the drivers door.(lock:ORANGE / PURPLE / unlock:pink/black) I usually try to pull the rubber boot out that the wires run in in between the door and the car. Sometimes there is enough slack to cut the wires there and then splice them and run to your relays under the dash. Follow the wiring diagram for the two relays and you will be working in no time. Good luck!
Brian
owner/installer
Sight & Sound Car Stereo
"all electronic equipment runs off of smoke, once you let it out, it stops working"
Saturday, February 7, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
