791xv starter kill
krazy3o4
Member - Posts: 15
Posted: June 16, 2004 at 9:09 PM / IP Logged
Ok  I've heard mixed stories about the supposed built-in starter kill in the 791xv.
Does it have one or not?
I know that there is a section in the remote start install, that says to cut the starter wire, but is this just for the anti-grind or will it actually work as a starter kill, if someone tries to start the car why the alarm is armed.
If there is a built-in starter kill, why do they include the orange (ground when armed) / starter kill wire?
Teamrf
Gold - Posts: 1,031
Posted: June 16, 2004 at 9:42 PM / IP Logged
Yes it doesn have one. Hook the one side of the starter wire to one side of the starter on the alarm, and the other to the other side.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
kwalton
Member - Posts: 28
Posted: June 16, 2004 at 10:53 PM / IP Logged
cut the starter wire. green side goes to the key switch and purple goes to the starter.
auex
Platinum - Posts: 5,041
Posted: June 16, 2004 at 10:55 PM / IP Logged
Teamrf wrote:
doesn
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
RufNUSD
Copper - Posts: 184
Posted: June 17, 2004 at 12:05 AM / IP Logged
Id like to confirm that it dosen have a starter kill. Yes it DOSE have a kill. In addition the orange wire can perform multiple tasks. Window roll up, addl siren wiring, proximity sensors... yaddee yaddee yaw.
Someone pass me that bottle.
swamprat323
Gold - Posts: 1,335
Posted: June 17, 2004 at 12:15 AM / IP Logged
I like to know this my self. But your answers are not very clear. ( no offense or anything).
If you just hook up the RS part to the starter wire, is this or is this not a starter kill?
If not, how do you hook a starter kill relay (orange wire) with along the RS part of the system.
RufNUSD
Copper - Posts: 184
Posted: June 17, 2004 at 12:22 AM / IP Logged
If you use the heavy gauge GREEN and PURPLE for a starter interruption, you have a starter kill circuit one the alarm is armed.
If you are concernced with adding addl cutoffs
86 Ign
85 Orange
30 Hot side starter
87a Cold side starter
You can use this with anything that prevents the vehicle from starting though not always encouraged by some.
Sunday, June 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
