Window module on 2004 Camry
IIrjII
Copper - Posts: 103
Posted: August 20, 2004 at 2:01 AM / IP Logged
I installed the rs 3.5 into my friends car and he just bought window modules for the front windows.  I pulled up directechs for the wiring info and the driver side wasn't a problem.  When I get to the passenger side i cut the wires that directechs said was the wires for the front passenger.  When i got done, the window in the back goes down, but thats it.  I reconnected the wires, and pulled the door switch for the front passenger side off so I could take a look at the wires.  I don't remember what the colors for the wires were for.
The problem is that after checking the wires with a multi meter, I cut the wires and hooked the wires up for the passenger side.  When we armed the alarm, it blew the fuse for the constant 12 volts.  I didn't have much time to correct it so we just left the passenger side out.
My question is, does anyone know what the wiring colors are for the front passenger window?
tbirdman74
Copper - Posts: 164
Posted: August 20, 2004 at 6:15 AM / IP Logged
LF Window up/dn    green - red                               driver window switch
RF Window up/dn   GREEN / WHITE - RED / black          driver kick, door harness
LR Window up/dn   GREEN/ YELLOW - RED / yellow      driver kick, door harness
RR Window up/dn  GREEN / WHITE - RED / black          driver kick, door harness
If it don't fit, Force it.
If it breaks, You needed a new one anyway!
IIrjII
Copper - Posts: 103
Posted: August 20, 2004 at 10:15 AM / IP Logged
So the passenger side front and rear are the same colors?  I remember looking for those colors and I only found one set, but i guess i'll take a look again.
Tuesday, February 3, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
