791xv antenna
davidosand
Member - Posts: 36
Posted: August 21, 2004 at 10:11 AM / IP Logged
I am really wanting to install the brain in the rear of a cargo van that has no windows at all except for the two front doors and the windshield. that means the antenna cable is not long enough to reach to the front glass. I still want the best range I can get, so I have 2 Questions. 1. Can the cable be extended? and 2. Can I mount it outside on the roof? If so, how do I make it weatherproof?
lilboi
Copper - Posts: 126
Posted: August 21, 2004 at 9:48 PM / IP Logged
I'm sure the cable can be extended. Just snip the wires, and add more length to it.
davidosand
Member - Posts: 36
Posted: August 23, 2004 at 10:54 PM / IP Logged
well, the local dealer told me that the range goes down horribly when you extend the cable. I'm not sure I buy that. It sounds more reasonable to me that you should be able to extend it. Don't know why DEI didn't anticipate the need for a longer cable.
auex
Platinum - Posts: 5,041
Posted: August 23, 2004 at 11:03 PM / IP Logged
You may be able to get away with putting the antenna behind the tail light. You should be able to use rubberized undercoating to weatherproof the antenna.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
jaxman
Copper - Posts: 185
Posted: August 24, 2004 at 2:33 AM / IP Logged
The range will CHANGE if you cut the wire and make it shorter or longer.
If it gives more or less range I can't tell , depends how lucky you are.
lilboi
Copper - Posts: 126
Posted: August 24, 2004 at 3:06 AM / IP Logged
I want to extend the range on my antenna. Mine is mounted right behind the rear view mirror. Anything i can add or change to make it stronger?
Wednesday, February 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
