Transponder colors
evnldr
Member - Posts: 36
Posted: August 22, 2004 at 12:16 AM / IP Logged
I need to know the colors of the wires and the one to cut
profuse007
Gold - Posts: 2,015
Posted: August 22, 2004 at 12:27 AM / IP Logged
what model car and bypass unit?
Houston,TX
evnldr
Member - Posts: 36
Posted: August 22, 2004 at 12:31 AM / IP Logged
Im making my own bypass unit out of a spair transponder chip and an extra ford transponder antena
Transponder colors -- posted image.
evnldr
Member - Posts: 36
Posted: August 22, 2004 at 12:33 AM / IP Logged
http://home.comcast.net/~evnldr/untitled.JPG
THE PIC
extreme1
Silver - Posts: 1,070
Posted: August 22, 2004 at 7:40 PM / IP Logged
you cannot do this with fords system as the PATS module is built into the key cylinder.
the easiest thing to do is take your PATS key, wrap 6-8 turns of 22-26awg wire around the top half of the key and leave a 12" pair of pigtails.
Next, make an antenna ring out of 8 turns of 22-26awg wire big enough to go around the key cylinder.
wire a relay
85- 12V
86- ground out while running
30. one of the pigtails from key
87- one of the pigtails from your antenna
join the remaining two pigtails together.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
Thursday, February 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
