Need help to uninstall alarm
thousandandone
Member - Posts: 31
Posted: September 21, 2004 at 5:47 PM / IP Logged
Hi, I'm very new to this field. I have a Legend 91 which has a Viper with 552V on it. The remote control has only 2 bottom ( I & II ). When I press II it will lock/unlock. However sometimes it keep horn when I open door. The starter not working at all. Now I want to install the Compustar 2way FM. What is the best to remove the old module?
Thanks in advance
Autostar
raydawg357
Silver - Posts: 769
Posted: September 22, 2004 at 10:09 AM / IP Logged
There should be only one wire that is cut and that's your starter wire.  Unplug the wiring harnesses from the brains of the alarm and reconnect the starter wire to itself.
Do it right the first time
Tuesday, May 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
