2004 Civic Remote Start
jazzy95tsi
Member - Posts: 36
Posted: December 11, 2004 at 2:40 PM / IP Logged
Hey guys i am installing a Code Alarm CA-535425PK in a 2004 Civic LX.  Any pointers or suggestions before I begin. Thanks in advance Jeff
Jeff 2004 Civic Remote Start -- posted image.
jazzy95tsi
Member - Posts: 36
Posted: December 11, 2004 at 3:03 PM / IP Logged
Hey Guys I need any diagrams and color codes/locations for for a 2004 civic.  I am installing a Code CA-535425.  keyless/remote start with defrost and a trunk solenoid .  Thanks in advance2004 Civic Remote Start -- posted image.
Platinum - Posts: 12,488
Posted: December 11, 2004 at 3:22 PM / IP Logged
Super easy installation. The immobilizer system is the only thing that you have to worry about. Get the PKH3 for this vehicle for Immobilizer bypass and if it's a standard, then the clutch wire is the light blue on the clutch are ( next to the BLACK wire ) and the emergency brake wire can be accessed at the Immobilizer plug as well so no need to run a wire to the e-brake switch itself.
hagmanti
Silver - Posts: 304
Posted: December 11, 2004 at 11:15 PM / IP Logged
In the first page of your installation is a web site that will supply wire locations and colors. Use it.
Also try bulldog and designtech. 7thgencivic has stuff specifically related to that model, for instance location of neutral safety switch (which I've posted elsewhere on the board recently.
Defrost might be yellow/black on a 14 pin green connector behind the defrost switch-- check this first! My source is quite suspect. Let me know what you find.
I would strongly recommend that, instead of a generic solenoid, you use an accord trunk opener-- see this post. 4 guys in our shop own various civics. We destroyed 4 trunk releases (2 dei, 2 code-alarm) before we discovered this. (not entirely sure that trick still works in a 2004, but I'd guess it does-- as on that board...)
PKH3 or 555I work well for immobilizer bypass.
Make sure to hook up doorpin, or you won't be able to program that brain.
Solder all connections. Go slow, take your time, DMM every wire before connecting something to it. Don't expect to use this car for a week if this is your first install.
Ask questions! I install that brand for a living, and I own the same generation civic.
Don't use the hood pin that comes w/ it (or only use it temporarily) buy a decent pin switch such as one of these. The ones that come w/ it rust out at the drop of a hat.
Make sure that the brain you get says REV:02 or higher on the unit itself (by serial number). If not, take it back and get one that does. (Trust me on this-- shock sensors were shaky, the earlier revisions used a 3-wire starter kill, tended to go bad for no reason, all sorts of yucky stuff).
Me
hagmanti
Silver - Posts: 304
Posted: December 11, 2004 at 11:19 PM / IP Logged
Oh yeah-- remember that you don't really have any sort of warranty if you do it yourself. Code will help you do the install, but you're on your own if you burn out the ECM.
It may seem crazy to spend almost as much (or more) to have it installed as it cost for the unit itself, but remember that the vast majority of what makes a good alarm system is how well it's put in your car...
Me
profuse007
Gold - Posts: 2,015
Posted: December 12, 2004 at 1:59 AM / IP Logged
hey jeff, whats the E-brake wire color for this civic?
Houston,TX
hagmanti
Silver - Posts: 304
Posted: December 12, 2004 at 9:55 AM / IP Logged
My guess-- GREEN/ ORANGE / 1 sil dot, in a "harness running above diag. Plug under dash". Frankly, I don't know what a "diag. Plug" is-- I'm copying verbatim from my source.
Me
Posted: December 12, 2004 at 10:28 AM / IP Logged
It's the GREEN/ ORANGE wire ( POS #4 ) this is (-) when ebrake is up.
jazzy95tsi
Member - Posts: 36
Posted: December 12, 2004 at 10:49 AM / IP Logged
I read the the warranty is good for the time that I own this vehicle and system?    If this is wrong than I may return it and buy a valet.
profuse007
Gold - Posts: 2,015
Posted: December 12, 2004 at 11:58 AM / IP Logged
thanks jeff
Houston,TX
