alarm is going crazy
daveangell200
Member - Posts: 14
Posted: December 11, 2004 at 6:01 PM / IP Logged
I have a clifford matrix 3 in my cavalier that seems to go off every 15 minutes. I just added a prox sensor and voice module a month ago but this just started today. What could be causing this, I was thinking it could be a bad sensor but I really dont know much about alarms.
swamprat323
Gold - Posts: 1,335
Posted: December 11, 2004 at 6:08 PM / IP Logged
Look at the LED ( see how many times it flashes)and then in the manural and see waht zone is being triggered.
snguyen
Silver - Posts: 281
Posted: December 11, 2004 at 6:13 PM / IP Logged
What zone is going off????  Did you install this yourself??  if not, it might be easier to take it back to the person that install this for you.
daveangell200
Member - Posts: 14
Posted: December 11, 2004 at 6:22 PM / IP Logged
zone 3 is going off. the manual says two stage progresses from warning to full alarm. It has a description of door switch circuit. Would that mean that a door might not be closed tightly. I took it in to quality auto sound to have them check it because the drivers side door wont lock or unlock with the remote and they said that since I replaced an acuator and added sensors that they wont warranty the alarm or their work. I need to try to figure this out myself so any more help would be appreciated.
swamprat323
Gold - Posts: 1,335
Posted: December 11, 2004 at 6:38 PM / IP Logged
When you added the sensors what zone did you hook them up to.
daveangell200
Member - Posts: 14
Posted: December 11, 2004 at 6:41 PM / IP Logged
I added the prox to the harness for the shock sensor and tapped the wires coming off of the brain for the voice module.
swamprat323
Gold - Posts: 1,335
Posted: December 11, 2004 at 6:49 PM / IP Logged
What year Cav. do you have?
daveangell200
Member - Posts: 14
Posted: December 11, 2004 at 6:50 PM / IP Logged
its a 2002
swamprat323
Gold - Posts: 1,335
Posted: December 11, 2004 at 6:57 PM / IP Logged
Check your door pin switches, may have one goign out on ya.
daveangell200
Member - Posts: 14
Posted: December 11, 2004 at 8:25 PM / IP Logged
how do I check if they are good. I have one more question while youre helping me. The alarm wont warn you away. It will give the warning chips and then go to full alarm. What could be causing that. Could it be the sensors I added.
Sunday, April 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
