Clifford parallel sensors
black_cabbie
Posted: February 07, 2005 at 4:54 AM / IP Logged
Hi all,
I have a clifford arrow 3 alarm which has outputs for 2 sensors only. One dual (4 wire warning/trigger) and one single (3 wire trigger only).
I have already installed a dual proximity sensor and I have a glass break sensor on the other output. Can I have a dual piezo sensor to work in parallel with the the dual proximity sensor and a tilt motion sensor to work with the break glass sensor? Somebody told me I could do it using diodes. Is it true?
Thanks in advance guys! Clifford parallel sensors -- posted image.
auex
Platinum - Posts: 5,041
Posted: February 07, 2005 at 8:57 AM / IP Logged
You can add as many sensors to the instant trigger wire as you want, and if there are any car triggers(hood/trunk) then you should use diodes on all triggers.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
black_cabbie
Posted: February 07, 2005 at 10:18 AM / IP Logged
Thanks for the reply! Clifford parallel sensors -- posted image.
Jolene?
Posted: February 07, 2005 at 1:52 PM / IP Logged
does anyone know where i can find a wiring chart for a clifford system?  I am looking for a friend...it's the one that shocks people when they touch the car...
auex
Posted: February 07, 2005 at 5:05 PM / IP Logged
OmarR
Copper - Posts: 162
Posted: February 07, 2005 at 9:21 PM / IP Logged
I think you would have to check with dealers in Africa.
gcorrea
Silver - Posts: 436
Posted: February 09, 2005 at 12:09 AM / IP Logged
or the one that spits fire  through the sides of the car.lol
gcorrea
Wednesday, June 12, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
