05' Ford Escape door trigger wire..
proinstall
Copper - Posts: 77
Posted: February 12, 2005 at 1:54 PM / IP Logged
Ok.. i'm stumped.. the car falses on the pink wire in the dome light harness which is where its supposed to be.. it works fine when testing.. but after a while of sitting it sets the alarm off saying the door is/was open..
Anyone else have this same issue?
profuse007
Gold - Posts: 2,015
Posted: February 12, 2005 at 2:44 PM / IP Logged
i assume youll need that wire to get the domelight to work so you cant diode it there.
youll need to grab antoher wire to diode isolate it from the GEM module. havent done this car but all the past ford w/ RKE have this issues.
trigger- (-) pink at the DKP/ door sill harness. this will grab all doors.
cut the wire, band of diode on trigger switch side along w/ the alarm (-) trigger input wire.
Houston,TX
mkaudio17
Member - Posts: 38
Posted: February 12, 2005 at 6:45 PM / IP Logged
sounds like sleepy doorlocks to me
Professionalism.
Monday, February 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
