Original Clifford Matrix problem
Brak
Posted: October 31, 2002 at 10:40 AM / IP Logged
I have the original Matrix system, about 10 yrs old, installed in a 92 Camaro.  I had a battery short that may have caused a problem with the remote arming, possible damage to the board.  Neither of my remotes work to activate the system or my hatch release.   If I disconnect/reconnect the battery, the alarm sounds and all features work but no remote.  I read thru my install manual and it mentions the remote antenna, I can't seem to find this or is it built into the board?  Also, is there a way to reprogram the remote?  Here is a link to the remote I have.........  http://www.autotechs.com/items/item225.htm
Any suggestions would be appreciated.
bigwilley
Member - Posts: 16
Posted: November 01, 2002 at 10:52 AM / IP Logged
My guess is that you will have to program your Matrix system to recognize your remote... not sure, just a thought.
Brak
Posted: November 01, 2002 at 11:35 AM / IP Logged
Do you know the procedure to do that.  I have read about opening doors, flipping the valet switch, etc.  My manuals just states that it is programmed to work when installed.   I do believe that I lost the programming when the battery shorted.  There is no visible damage to the board.
bigwilley
Member - Posts: 16
Posted: November 01, 2002 at 12:19 PM / IP Logged
Not sure, but you could probably contact the manufacturer and I'm sure they would tell you.
