05 Mercury Sable RS ?
Welcome Guest :)
Ren92
Copper -
Posted: April 05, 2005 at 8:14 PM / IP Logged
Does anyone have the wire colors for an 05' Sable? I have everything but the tach but it would be nice have the rest.
Ren92
Copper -
Posted: April 05, 2005 at 9:57 PM / IP Logged
Ren92
Copper -
Posted: April 05, 2005 at 11:33 PM / IP Logged
will the 555F work for this car also?
clank
Member -
Posted: April 05, 2005 at 11:39 PM / IP Logged
Parking Lights- | N/A | | |
Hazards | same as turn signal wires | | |
Turn Signal(L) | lt grn/wht (F), lt grn/org (R) | + | steering column |
Turn Signal(R) | wht/lt blu (F), org/lt blu (R) | + | steering column |
Reverse Light | BLACK/ pink | + | kick panel, harness to rear |
Door Trigger | see notes | - | GEM, 26 pin plug |
Notes: The LF door trigger is yellow/black in pin 5. The RF door trigger is gray/red in pin 19. The LR door trigger is lt. GREEN/ YELLOW in pin 20. The RR door trigger is pink/lt. blue in pin 7. Use all four wires and diode isolate each.The GEM (Generic Electronic Module) is part of the SJB (Smart Junction Box) to the left of the steering column. It has three plugs on the bottom. |
Dome Supervision | BLACK/ lt. blue | + | SJB, top plug, pin 22 |
Notes: The SJB (Smart Junction Box) is the fuse/relay box to the left of the steering column. It has three plugs to the left of the fuses. |
Trunk/Hatch Pin | see notes | - | see notes |
Notes: On the sedans use BLACK/ pink at the light in the trunk. On the wagons use WHITE/ purple at the GEM, 26 pin plug, pin 21.The GEM (Generic Electronic Module) is part of the SJB (Smart Junction Box) to the left of the steering column. It has three plugs on the bottom. |
Hood Pin | tan/lt. green | - | GEM, 26 pin plug, pin 17 |
Notes: The GEM (Generic Electronic Module) is part of the SJB (Smart Junction Box) to the left of the steering column. It has three plugs on the bottom. |
Trunk/Hatch Release | purple / YELLOW | - | GEM, 26 pin plug, pin 3 |
Power Sliding Door | N/A | | |
Factory Alarm Arm | arms on lock with door open | | |
Factory Alarm Disarm | pink/white | - | GEM, 26 pin plug, pin 4 |
Disarm No Unlock | see factory alarm disarm | | |
Tachometer | NOT red | ac | ign coil/coil pack or fuel injector |
Wait to start | N/A | | |
Brake Wire | RED / lt. green | + | brake pedal switch |
Parking Brake | lt. green | - | switch or GEM, 26 pin plug, pin 1 |
Horn Trigger | dk. blue | - | column or SJB, bottom plug, pin 1 |
Memory Seat 1 | N/A | | |
Memory Seat 2 | N/A | | |
Memory Seat 3 | N/A | | |
Immobilizer Bypass Module: | Required: Yes | Type: SecuriLock | Part #: 556S, 556U, or 555U |
Notes: N/A |
This wiring information is being provided free of charge on an "as is" basis, without any representation or warranty. It is your responsibility to verify any circuit before interfacing with it using a digital multimeter.Directed electronics, Inc. assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information. |
shocker
clank
Member -
Posted: April 05, 2005 at 11:43 PM / IP Logged
2005 / Remote Start [PRINT THIS PAGE] 12volts | lt. GREEN/ purple (40A) | + | ignition harness | Starter | RED / lt. blue | + | ignition harness | Second Starter | N/A | | | Ignition | RED / lt. green | + | ignition harness | Second Ignition | N/A | | | Third Ignition | N/A | | | Accessory | gray / YELLOW | + | ignition harness | Second Accessory | BLACK/ lt. green | + | ignition harness | Keysense | BLACK/ pink | - | ign harn or GEM, 20 pin plug, pin 17 | Notes: The GEM (Generic Electronic Module) is part of the SJB (Smart Junction Box) to the left of the steering column. It has three plugs on the bottom. | Power Lock | pink / YELLOW | - | GEM, 26 pin plug, pin 18 | Notes: The GEM (Generic Electronic Module) is part of the SJB (Smart Junction Box) to the left of the steering column. It has three plugs on the bottom. | Power Unlock | pink/lt. green | - | GEM, 26 pin plug, pin 6 | Notes: The GEM (Generic Electronic Module) is part of the SJB (Smart Junction Box) to the left of the steering column. It has three plugs on the bottom. | Lock Motor | pink/black | 5wi | SJB, top plug, pin 3 | Notes: The SJB (Smart Junction Box) is the fuse/relay box to the left of the steering column. It has three plugs to the left of the fuses. | Unlock Motor | RED / white | 5wi | SJB, top plug, pin 2 | Notes: The SJB (Smart Junction Box) is the fuse/relay box to the left of the steering column. It has three plugs to the left of the fuses. | Parking Lights+ | brown |
shocker
Monday, June 10, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
