Bypass notification chirp
stingray_01
Member - Posts: 23
Posted: June 11, 2005 at 1:37 AM / IP Logged
Hi
I've got the 791XV installed and when I arm the car, 3 seconds later the siren chirps again. I checked the manual and this is supposed to indicate a bypass notification. I looked at the led and it's flashing twice. The thing is my remote doesn't recieve any zone bypass indication and I tested each one of my sensors and they are still setting the alarm off as usual. Do you know what could be causing this, is it even a bypass notification?
Powermyster
Silver - Posts: 962
Posted: June 11, 2005 at 6:03 AM / IP Logged
who installed it
stingray_01
Member - Posts: 23
Posted: June 11, 2005 at 7:43 AM / IP Logged
A person who works at JB Hi-Fi doing audio and alarm installs. So it was done by someone with experience, in other words not by myself.
auex
Platinum - Posts: 5,041
Posted: June 11, 2005 at 8:29 AM / IP Logged
Your installer took a half assed way out of using independant door triggers. At any rate there are 2 ways to resolve your problem.
1. Hook the alarm up correctly to the door triggers and NOT the dome light.
2. Door error chirp is a programable option. It may only be accessible by bitwriter so check the install guide.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
stingray_01
Member - Posts: 23
Posted: June 11, 2005 at 7:04 PM / IP Logged
Door sensor bypass chirp ON/OFF is for cars with factory domelight delay. My car doesn't have that so it shouldn't be the problem.
auex
Posted: June 11, 2005 at 11:50 PM / IP Logged
What kind of car is it? The only time that should chirp is if the door trigger shows it as being open. Now it could be the -multiplex input(hood trunk etc...) that is causing the error but either way it is install related.
stingray_01
Member - Posts: 23
Posted: June 12, 2005 at 1:58 AM / IP Logged
Installed into a Skyline R32.  When a zone is bypassed the remote should display it shouldn't it? Well the remote doesn't come up with anything. If it's install related I'm going to have to take it back to him.
stingray_01
Member - Posts: 23
Posted: June 21, 2005 at 12:40 AM / IP Logged
An update, I umplugged the proximity sensor today and it stoped chirping. Could it be a faulty proximity or the way the installer wired it. If  the proximity sensor was wired to the same wire as the shock, could this cause it to interfere and set of the bypass chirp?
accord78
Copper - Posts: 97
Posted: June 23, 2005 at 5:25 PM / IP Logged
it might be since when u close the door the shock sensor is still shaking that might send a signal to the proximity sensor and cause it to chirp.... just an idea
gus1
Gold - Posts: 1,013
Posted: June 23, 2005 at 8:30 PM / IP Logged
You can also turn off the open door chirp to make sure.... menu 2, feature 6. You can also bypass sensors remotely. When arming, press arm again within 5sec, and it'll bupass the shock, press again, and the next sensor is bypassed. This is assuming the installer took advantage of the multiplex sensor input......
Gus
Tuesday, May 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
