any way to arm/disarm fact alarm in a g6?
meltingplastic
Copper - Posts: 225
Posted: November 01, 2005 at 9:34 PM / IP Logged
hey guys,
i did a remote start in an 06 g6 today.. it went really well when i caught all the wires in the driver kick instead of the bcm..   but my question is, i had to hook up the unit sans keyless cause the factory alarm only arms and disarms through the factory remote.. to me i felt as if the install was half assed cause the customer couldnt use the entire keyfob from the 160xv.   has anyone found a way to arm and disarm the factory alarm? i would like to know for the next unit i do.
Driving a Bagged, Caddied 02 s10
KarTuneMan
Platinum - Posts: 7,056
Posted: November 02, 2005 at 12:08 PM / IP Logged
It will arm on lock and a dissarm wire can be found at the BCM, connecter 1, pin 35 Lt.grn. (NEG)- pulse thru a 500ohm resistor.
meltingplastic
Copper - Posts: 225
Posted: November 02, 2005 at 6:14 PM / IP Logged
thanks man.. now for the next one i know... directechs says only arms and disarms through factory remote but i knew there had to be a way..   also the bcm was a B to get to the wires.. i found c1 running to the driver side of the console and down..   any advice on getting these wires next time? i found the ones i needed int he kickpanel and if i have to go to the bcm i'm kinda dreading it lol
Saturday, March 7, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
