Changing alarm system
colour
Member - Posts: 6
Posted: November 01, 2005 at 10:24 PM / IP Logged
Okay this is what I have I have an alarm already installed and I have figured out what wires are which. I am going to simply change to a different alarm and everything hooks up the same except for the door locks. On my old alarm there are six wires two unused (brown & white), two (purple) connected to ground, one (blue unlock common)and one (green lock common). Now on the new alarm I only have three wires one (green neg.lock, Pos. unlock)another (blue pos lock, neg. unlock)and a third (blue/red neg. 2nd unlock)
This is a negative lock, do I hook up the new (green neg. lock - pos. unlock) to the (blue unlock common)and the new (blue pos. lock - neg. unlock) to the old(green lock common)? And then leave the new (blue/red) unhooked? Thanks.
05gt
Silver - Posts: 628
Posted: November 01, 2005 at 10:27 PM / IP Logged
wouldn't it be the other way geen from the alarm brain to the old green, and the blue to the old blue
cause on negative power locks the green is lock and the blue is unlock
the blue/red is not needed
colour
Member - Posts: 6
Posted: November 01, 2005 at 10:37 PM / IP Logged
Gee didn't even notice the colors were the same answered my own question if I would have read it!!. But what's the deal with the two purple wires on the old system being grounded?
05gt
Silver - Posts: 628
Posted: November 01, 2005 at 10:40 PM / IP Logged
not 100% sure, someone else will have to answer that for you
did you have actuators put in your car or does your car already have power door locks
if your car has power door locks just get rid of all the old door lock wiring and connect the green wire to the lock wire in the car, and the blue wire to the unlock wire in the car
colour
Member - Posts: 6
Posted: November 01, 2005 at 11:17 PM / IP Logged
It already has power locks.
05gt
Silver - Posts: 628
Posted: November 01, 2005 at 11:21 PM / IP Logged
well do what i said one post ago, the last line of my post
Hornshockey
Silver - Posts: 520
Posted: November 01, 2005 at 11:24 PM / IP Logged
sounds like you have a relay pack similar to the DEI 451M installed; the two purple wires are a ground input for that relay pack. It basically allows a stronger ground signal to be sent to the lock wires than the hundred milliamps or so that the wires directly from the brain put out.
Life moves pretty fast; if you don't stop and look around once in a while; you could miss it.
colour
Member - Posts: 6
Posted: November 01, 2005 at 11:41 PM / IP Logged
Yea I thought that the old alarm might have a built in relay. But will the new alarm work without the relay?
05gt
Silver - Posts: 628
Posted: November 01, 2005 at 11:42 PM / IP Logged
yep it will, just do what was said
Saturday, March 7, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
