1999 dodge ram clutch switch bypass
jmacf14
Copper - Posts: 160
Posted: December 28, 2005 at 12:08 AM / IP Logged
 i am installing a remote start alarm (ultrastart2256m) on a 1999 dodge ram 5 speed, i need to bypass the clutch during start, do i need a relay?   tnx jmacf14
jmacf14
KarTuneMan
Platinum - Posts: 7,056
Posted: December 28, 2005 at 9:18 AM / IP Logged
you can take the starter wire from the R/S unit, and connect it directly to the yellow/red @ the clutch, instead of the Ign. harness.
I cannot remember how the safety feature work for the AST starters. At any rate, this yellow/red needs a POS(+) start signal.
REMEMBER....you need to tag your hand brake AND your door pins to safely start this thing..1999 dodge ram clutch switch bypass -- posted image.
jmacf14
Copper - Posts: 160
Posted: December 28, 2005 at 3:40 PM / IP Logged
 thanks,i was hoping that it was as simple as that. i really apreciate the info!  jmacf14
jmacf14
