Autochamps R/S 315-001
Trav3D1
Copper - Posts: 146
Posted: March 20, 2006 at 7:14 PM / IP Logged
I just installed a Autochamps r/s on a 1993 Toyota Camry.  This alarm has been an absolute mess, and I have seen numerous things that I have never seen a alarm do.
1.) I start the car up with the key, and the parking lights continue to blink for approx. 1 minute, then I take the key out and the car continue to run. (go figure)  The only way the car shuts down is if I take the fuse to the alarm out.
2.) I disconnect the fuse to the alarm and when I start the car up with the key, the starter disable doesn't allow me to start the car, and the siren goes off. (go figure)  The only way I got it to stop was to pull the brain of the alarm out.
Any suggestions......I called the manufacture in New York and they could not even explain a resolution to my problem.  In addition, the installation instructions are noting more than a wire diagram.  I have doubled and even triple checked my work, as a 93 Camry is one of the easiest cars to work on.
Trav
xscash
Copper - Posts: 317
Posted: March 20, 2006 at 7:57 PM / IP Logged
i know this really doesnt help...but how about trying another unit?...
Trav3D1
Copper - Posts: 146
Posted: March 21, 2006 at 1:59 PM / IP Logged
My customer actually purchased two of these alarms and I was thinking about changing out the brain to see what happens.  If that did not work, I was going to recommend pitching the entire alarm.
In addition, the tech support (which happens to be the manufacture and distributor) was virtually useless.
Trav
Friday, February 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
