2006 Ford F-250 Tach Wire
ride9678
Posted: March 28, 2006 at 3:37 PM / IP Logged
I'm installing a viper 160xv in a 2006 Ford F-250 Superduty
Diesel. I hooked the tach wire to the GREEN / WHITE wire in the harness above the e-brake. The wire tests ok bit the viper won't program that wire properly. Does anyone have any ideas or a better tach wire to connect to?
customak47
Copper - Posts: 164
Posted: March 28, 2006 at 4:09 PM / IP Logged
This wire is the best source for tach signal. if you have a problem with it programming, it is in the unit, programming procedure,  or the install. Going anywhere else would be a waste of time.
My rifle is my friend...
extreme1
Silver - Posts: 1,070
Posted: March 28, 2006 at 5:16 PM / IP Logged
set the starter for 4 second crank and no engine checking.
it has built in anti-grind.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
johnmax
Copper - Posts: 131
Posted: March 28, 2006 at 5:53 PM / IP Logged
We can't even get that to work. We've been using DEI tach generators on those, as DEI recommended. No problems. But when we use Audiovox remote starts, that GREEN / WHITE works fine. No comebacks.
warpedimage3
Copper - Posts: 90
Posted: March 29, 2006 at 5:32 PM / IP Logged
try changing the tach threshold to low with a bit writer and see if that works
bhurlebaus
Member - Posts: 22
Posted: March 29, 2006 at 9:33 PM / IP Logged
I had this problem with an Audiovox 1 button I tried other locaations off the ecu but none of them worked. Even tried a pulse timer. For the Ford factory remotestarts they have a tach signal generator. Didnt work for me but maybe for you. Finnaly tech support said the lower models couldnt read the tach on the 06 f150 and had to upgrade to a rs/keyless.I dont know if this helps you with the Dei as we only work with Audiovox .
