Autopage Temp Sensor
Jimbob
Member - Posts: 49
Posted: January 23, 2003 at 7:44 PM / IP Logged
I just installed an Autopage RS750 LCD and the temp does not display when I puch the start and trunk buttons together.  Anyone ever run into this problem, or had a bad sensor?  Do I need to set it up for it to work or should it work without doing anything special to it?
Jimbob
Beverly Hills
securinu
Silver - Posts: 772
Posted: January 23, 2003 at 10:58 PM / IP Logged
it is "set" and "trunk" i believe ,at least on my marksman unit it is.
Jimbob
Member - Posts: 49
Posted: January 23, 2003 at 11:30 PM / IP Logged
I tried that after you mentioned it and it looks like that sets the clock alarm.  My manual says it is start and trunk.  I will probably try sending back the sensor.   Thanks
Jimbob
Beverly Hills
gmc4x4
Copper - Posts: 62
Posted: January 24, 2003 at 12:23 AM / IP Logged
its the trunk and panic..or the red and black one's , at least thats how my 750lcd works..
Jimbob
Member - Posts: 49
Posted: January 24, 2003 at 9:04 AM / IP Logged
Thank a lot Sean,  That was it.  My manual is wrong.
Jimbob
Beverly Hills
Tuesday, June 11, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
