06 GTO wiring diagram
Welcome Guest :)
macdammitman1
Member -
Posted: November 27, 2006 at 4:14 PM / IP Logged
Im looking for a wiring diagram for a 2006 Pontiac GTO.
Q Tha Kid
KarTuneMan
Platinum -
Posted: November 27, 2006 at 5:14 PM / IP Logged
| Wire/Function | Colour | Location/Description | Polarity |
| PASSIVE ANTI-THEFT | YES | TRANSPONDER | SEE NOTES |
| 12 VOLTS | Go to battery | | |
| IGNITION | Orange | Ignition switch harness | + |
| | | These wires are small gauge but can be connected normally. |
| ACCESSORY | BROWN / white | Ignition switch harness | + |
| STARTER | Violet | Ignition switch harness | + |
| TACH SIGNAL | Use an injector | | |
| LOCK | BROWN / white | At BCM behind glovebox | - |
| UNLOCK | Lt.GREEN/ YELLOW | At BCM behind glovebox | - |
| DOORPIN | SEE NOTES | | |
| | | Drver's door (Gray/white) and Passenger door (White). Both wires are located at the BCM behind the Glovebox. |
| TRUNK PIN | YELLOW /GREEN | At BCM behind glovebox | - |
| TRUNK RELEASE | BLACK/ red | At switch in dash | - |
| FACTORY ARM | Through OEM remote only | | |
| FACTORY DISARM | Through OEM remote only | | |
| | | System will disarm automatically during remote start when the ignition comes on and the transponder key is installed. |
| BRAKESWITCH | Blue/red | At switch above brake pedal | + |
| PARKLIGHTS | Brown | On fuse box under driver's dash | + |
| HORN | BLACK / YELLOW | At steering column | - |
| VSS WIRE | Violet/white | driver kick panel (at power interface module) | AC |
| DATABUS INTERFACE | Pin-2(top row from left) | Diagnostic plug below dash | DATA |
Available Notes
| PLEASE NOTE: This vehicle is equipped with TRANSPONDER chips in the ignition keys. This will need to be bypassed for Remote Starter installation. A keyless bypass module may be available, contact your distributor to find out. If one of these modules is not available to you, see the appropriate security diagram for bypass instructions. |
macdammitman1
Member -
Posted: November 28, 2006 at 2:25 PM / IP Logged
Thanks alot........ Why is it so hard 2 find these digrams??? Is there a site that has all the cars??
Q Tha Kid
Twelvoltz
Platinum -
Posted: November 28, 2006 at 5:49 PM / IP Logged
There are a few options that are free without requiring being a dealer to get access. The best I have found is techservices.audiovox.com, completely free and pretty accurate.
Thursday, January 29, 2026
• Copyright © 1999-2026 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
