tundra door locks messed up
thomasl
Member - Posts: 10
Posted: March 02, 2007 at 6:00 PM / IP Logged
 Have a problem with my door locks- the remote to the keyless entry stopped working. Could this be the brain to the keyless entry, or could it be the relay up in the kick pannel? I can manually lock and unlock the doors fine with the power switch, so Im thinking it could be the brain to the keyless entry? I dont know which one to try to replace..any info would be gratly appreciated! Thanks!!
Scott35
Silver - Posts: 258
Posted: March 02, 2007 at 6:59 PM / IP Logged
Changed the battery in your remote?
Tacomacrew
KarTuneMan
Platinum - Posts: 7,056
Posted: March 02, 2007 at 7:12 PM / IP Logged
What method did you use to connect the wires???? Solder, cut and butt, T-taps? Check the connection as well.
Is it an aftermarket alarm/keyless/remote start? What choo got main?
thomasl
Member - Posts: 10
Posted: March 02, 2007 at 7:56 PM / IP Logged
no I tried installing an aftermarket remote start with keyless entry. And I tapped into one of the wires without disconnecting the ground. So I think it blew something somewhere...hehehe. Im guessing it may be the brain- but could be the relay?
On a side note: I cant find anywhere here in Atlanta that will install my aftermarket(Commando) security system w/ remote start. No one will do it unless its bought from them. Anyone know of someonewho can around my area? Thanks!
Saturday, June 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
