no luck with xk04
dea,can
Copper - Posts: 284
Posted: September 15, 2007 at 2:59 PM / IP Logged
hi there no luck with the xk04 with new fireware 3-1 .platform #04/ fireware:pkford
thing will not hold a program anyone have a ideal went thought all my wiring  back to the old way  with a relay spare key works fine.
dragon
chadwa2003
Copper - Posts: 353
Posted: September 15, 2007 at 8:03 PM / IP Logged
What kind of car are you doing I use them all the time with no complaints
dea,can
Copper - Posts: 284
Posted: September 15, 2007 at 8:17 PM / IP Logged
2007 ford escape
dragon
chadwa2003
Copper - Posts: 353
Posted: September 15, 2007 at 8:41 PM / IP Logged
You should be okay to use the pkford version 2 do you have other xk04 to try or maybe you could reflash if you have an xkloader
dea,can
Copper - Posts: 284
Posted: September 15, 2007 at 8:50 PM / IP Logged
if you put the first key in security light comes on then goes off put second key in within 5 secs security light goes on and off remove second key push start button modulator light comes on everything powers up modulater led light comes on and flashes fast and security light on dash flashes fast and nothing happens. If you leave the key in the ignition starts fine. I have reset it a few times re did it a couple times and still didn't work. I had it flashed at visions still didn't work. Seems like the modulater isn't recieving the signal.
dragon
init
Copper - Posts: 93
Posted: September 15, 2007 at 9:17 PM / IP Logged
How did you connect the wires from the bypass to the wires in the car?
I've also heard that the learn routine for adding keys to the car can sometimes be locked by the dealer.  I don't know if that's true or not, you might need to look into it if the problem persists.
extreme1
Silver - Posts: 1,070
Posted: September 15, 2007 at 9:18 PM / IP Logged
won't work on the 06+ escape,explorer, tribute or the fusion.
use a pkf3 if you have one ( no wiring changes) or adstb from idata, or a pkuf2 or pats3+
Shaughn Murley
Visions Electronics
Red Deer, Alberta
dea,can
Copper - Posts: 284
Posted: September 15, 2007 at 9:38 PM / IP Logged
when you go to bypasskits.com it says that 2001 to 2007 support this bybass ...both pats type 1 and pats type 2 &3
dragon
extreme1
Posted: September 15, 2007 at 10:08 PM / IP Logged
yeah, it says that, also says 3.0 fixes bugs with fusion, sorry, it doesn't work with the 4 vehicles I listed
Shaughn Murley
Visions Electronics
Red Deer, Alberta
rtperformance
Member - Posts: 17
Posted: September 15, 2007 at 11:25 PM / IP Logged
Really it dose. I have used this on tons of 07 escapes. I didn't need to flash them or anything. I do know if you are not use to them the instructions are scarry. the only wires you need are
Red 12volt
Black Ground
Brown neg trigger input
Pink RX wire
Green TX wire
also when you look at the plug in the instructions it is backwardes. it is a pic from the front of the plug you may be on the wrong wires.
when programing: key1 in and to on
LED will come on, when LED gose off, Key1 off
Key2 in and to on
LED will come on, When LED gose off, Key2 off
Remote start,
Led will come on (car will not start), All shut down
Attempt 2 second start Ing on then start. You are now programed.
I HAVE DONE THIS ON SEVERAL 07 FORD ESCAPES!!
Tuesday, May 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
