relay
geo2slow4u
Posted: November 28, 2009 at 8:15 PM / IP Logged
I need some help. I lost my diagram I used to have. What I am trying to do is. I have a momentery switch for my orverdrive button on my car. I wanna be able to turn my overdrive off then hit a switch and be able to use the button for my nitrous.
Platinum - Posts: 13,725
Posted: November 28, 2009 at 8:51 PM / IP Logged
Do you know if the other wire of the switch is connected to power or ground?  Do you know were the switched wire connects to the computer?
geo2slow4u
Posted: November 28, 2009 at 9:56 PM / IP Logged
I forgot about that. I am pretty sure its a hot. Not sure where the wire connects to the computer. But the last time I did it, I did all the connections in the column.
Posted: November 28, 2009 at 10:16 PM / IP Logged
If you know where the wires are in the column, that will be fine.   Give me a minute, I will draw you a picture.
relay -- posted image.
Friday, February 27, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
