Relay with Built-In Replaceable Fuse
agemax
Member - Posts: 46
Posted: April 01, 2020 at 7:04 AM / IP Logged Link to Post Post Reply Quote agemax
Hi, i have searched the forums but cant seem to find an answer.
Is it ok to use a 12v relay with a built in replacable fuse? Are there pro's and cons to using these compared to a relay with a fused cable to supply them?
agemax
Member - Posts: 46
Posted: April 02, 2020 at 5:32 PM / IP Logged Link to Post Post Reply Quote agemax
Due to the lack of replies i am assuming nobody uses this type of relay? Relay with Built-In Replaceable Fuse -- posted image.
wirewise
Moderator - Posts: 489
Posted: April 02, 2020 at 5:44 PM / IP Logged Link to Post Post Reply Quote wirewise
Never a good idea to assume.
~wirewise~ Verify all wiring with your meter before making any connections!
Tuesday, May 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
