12VDC Timer, Off The Shelf?
itolond
Copper - Posts: 87
Posted: August 22, 2020 at 5:57 PM / IP Logged Link to Post Post Reply Quote itolond
Seeking this for a custom Automotive application - seeking a 12VDC (10A max) timer NO which cycles NC   (adjustable delay and NC time) when it receives a 12VDC input - preferable IP67
off the shelf somewhere?
eguru
Copper - Posts: 340
Posted: August 23, 2020 at 8:16 PM / IP Logged Link to Post Post Reply Quote eguru
You don't state how long a delay you require but this will probably work for you:
https://www.amazon.ca/PAC-TR-7-Universal-Trigger-Output/dp/B0002J22BO/ref=sr_1_1?dchild=1&keywords=pac+tr7&qid=1598231626&sr=8-1
itolond
Copper - Posts: 87
Posted: August 23, 2020 at 10:35 PM / IP Logged Link to Post Post Reply Quote itolond
Hi and Thanks
delay adjustable from 1-10seconds,
isn't this for car stereos?
itolond
Copper - Posts: 87
Posted: August 26, 2020 at 5:49 PM / IP Logged Link to Post Post Reply Quote itolond
I did to checking on the unit prescribed (TR7)- seems straight forward but it is not exactly clear to me. Do you know if this can be programmed with 4second on 3 second off cycle or similar?
eguru
Copper - Posts: 340
Posted: August 26, 2020 at 8:13 PM / IP Logged Link to Post Post Reply Quote eguru
I don't understand what you mean when you talk about an off time. Output will be off after the 4 second on time. Are you wanting some kind of repeating 4 on/3 off as long as the trigger is active?
itolond
Copper - Posts: 87
Posted: August 26, 2020 at 8:27 PM / IP Logged Link to Post Post Reply Quote itolond
Yes the operation as suggested (a boolean example)
IF Input 12VDC+ energised Then;
Sub output_cycle
Output 12VDC+ energised for 4 seconds,
Output 12VDC+ not energised for 2 seconds
Loop
End sub
Else End
eguru
Copper - Posts: 340
Posted: August 27, 2020 at 7:25 AM / IP Logged Link to Post Post Reply Quote eguru
Why not just build this with 555 timer (or many derivatives)?
https://www.electroschematics.com/pulse-generator-with-555/
itolond
Copper - Posts: 87
Posted: August 27, 2020 at 3:44 PM / IP Logged Link to Post Post Reply Quote itolond
That would be a last resort - still need to manager 10A draw as well
itolond
Copper - Posts: 87
Posted: August 27, 2020 at 3:52 PM / IP Logged Link to Post Post Reply Quote itolond
I take it this unit does not provide for what I need?
eguru
Copper - Posts: 340
Posted: August 27, 2020 at 5:26 PM / IP Logged Link to Post Post Reply Quote eguru
IDK how to do it with a TR7.
Add a power MOSFET to the example 555 circuit in the link I provided.
A relay won't last very long if you are cycling it twice every 7 seconds.
Sunday, June 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
