Reverse Polarity Solenoid Relay
epyon677
Posted: April 19, 2022 at 5:32 AM / IP Logged Link to Post Post Reply Quote epyon677
In the process of wrapping up a engine and harness conversion on my car.
The car has a factory alarm that used a vacuum pump style central locking system. Pulled the wiring back to the fuse box and replaced that system with the Type D positive trigger reverse polarity relay setup.
This setup works for the locking pulse. However upon testing the positive trigger from the CCM, it's only pulsing 3.8 volt to unlock. I'm guessing this isn't enough to trigger the relay, as the lock signal is pulsing 10v to the relay.
You can hear and feel it faintly trying to click, but at the minute stuck for ideas.
Can anyone share any ideas?
geepherder
Platinum - Posts: 3,668
Posted: April 19, 2022 at 10:37 PM / IP Logged Link to Post Post Reply Quote geepherder
You could try a lower voltage relay (5 volts) or use a transistor/resistors to trigger your setup.
epyon677
Posted: April 20, 2022 at 8:28 AM / IP Logged Link to Post Post Reply Quote epyon677
I'll be honest, didn't think of seeing if there was a lower voltage relay option. However after checking I can't find one that isn't a "micro" relay for PCB's. I've set this up using automotive 12v relays.
The relays I'm using is a pair Siemens Tyco ones. However I think they are 40amp, not 30amp like I originally thought. Shouldn't make any difference as the 12v feed is 15amp fused.
I've bought another CCM in case the voltage trigger from that is buggered.
If you have links to a different relay that would be appreciated.
Platinum - Posts: 13,674
Posted: April 20, 2022 at 8:12 PM / IP Logged Link to Post Post Reply Quote i am an idiot
The relay is 40/30 amp. 40 amps in the energized position and 30 amps on the normally closed contacts.
Wednesday, May 29, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
