New to relays, please help
Plan 9
Posted: October 22, 2003 at 3:20 AM / IP Logged
I'm sure there is a relay for what I need, I just don't know how to go about finding it.
I need a circuit to be closed, when ever another circuit loses power. So basically the relay will have power, second circuit will be open. Relay loses power, second circuit closes.
If you guys could help me find this, it would be greatly appreciated.
NowYaKnow
Gold - Posts: 1,217
Posted: October 22, 2003 at 4:55 AM / IP Logged
Here's one way to make it work..Get a normal 5 pin bosche style 30A relay from an auto store or something.
Pin 85: Tie this pin into the first circuit that has power.
Pin 86: Run this to ground.
Pin 30: Run this to fused 12v assuming you want the second circuit to have 12 volts when the first turns off.
Pin 87: Don't connect to anything
Pin 87a: Connect to the 12v side of the second circuit you want to power up.
Not sure how good you are with relays so here's a quick explanation of how it works..When circuit 1 is ON the relay is energized (pins 85/86 is the coil) and pins 30 and 87 on the relay are common. (ie second circuit is DEAD). Now turn the first circuit off and the coil of the relay shuts down making 30 and 87a common. (ie: second circuit gets 12v and turns ON). Good luck hope that helps.
Mike
Plan 9
Posted: October 22, 2003 at 5:23 PM / IP Logged
I think I've got it. When my circuit on 85/86 opens, it closes a circuit across 30/87a.   Correct?
If I followed you correctly, then I should be good.
Thanks!
Plan 9
Posted: October 22, 2003 at 5:28 PM / IP Logged
I just found a diagram of a bosch relay, I've got it figured out now.
http://www.classictruckshop.com/clubs/earlyburbs/projects/bosch/relay.htm
Thanks again!
Monday, February 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
