provide ground when powered
ewingr
Copper - Posts: 60
Posted: August 26, 2007 at 2:28 PM / IP Logged
I have an older car with a newer engine, and I want to have my fan on my engine turn on when I turn on the A/C. I was thinking I could run a wire to a relay from my compressor power wire that would provide 12v when the compressor comes on. I would like that to trigger a ground at a relay, which I figured I would wire into the ground on my fan relay. Sound possible?
I've looked at the diagrams on relays here, but don't see a situation for what I want, and don't know enough about wiring to figure that out. Hoping for some direction.
So, hot wire from A/C (when A/c turned on) to what pole on the relay?
Ground wire from my fan relay to what pole on the relay?
I am thinking power to the relay to 30.
Ground to the relay to 85?
What type of relay? SPDP?
Many thanks!
Roger
the12volt
Administrator - Posts: 3,959
Posted: August 26, 2007 at 3:40 PM / IP Logged
Using an SPDT relay, connect terminal 85 to power from A/C. Connect ground to terminals 86 and 30. Terminal 87 will be ground out from relay to fan relay.
provide ground when powered -- posted image. the12volt • Support the12volt.com
hotwaterwizard
Silver - Posts: 1,350
Posted: August 26, 2007 at 10:17 PM / IP Logged
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
ewingr
Copper - Posts: 60
Posted: August 29, 2007 at 9:12 PM / IP Logged
Thanks! I'll give it a try this weekend. I appreciate your response.
Roger
hotwaterwizard
Posted: August 29, 2007 at 9:56 PM / IP Logged
For switching the negitive look at this.
Stockton California
ewingr
Copper - Posts: 60
Posted: August 31, 2007 at 10:50 PM / IP Logged
Thanks, The 12Volt Administrator. This worked perfect, and providing me with specific wires to specific terminals was very very helpful.
Roger
Monday, April 27, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
