06 pontiac g6 gtp coupe
stuntinonabusa
Member - Posts: 44
Posted: January 24, 2008 at 8:15 PM / IP Logged
looking to get the directwire scheme or any other available for this vehicle.  it seems that the installer is having some issues with my ride and me being an installer at a best buy for a number of years in the past, i would like to see what all is involved with my vehicle so perhaps i can give these guys some pointers...
if at first u dont succeed........ lower ur standards
KarTuneMan
Platinum - Posts: 7,056
Posted: January 25, 2008 at 1:00 AM / IP Logged
12 VOLTS RED / white (see notes) Ignition switch harness   +
 IGNITION Pink Ignition switch harness   +
 ACCESSORY Brown Ignition switch harness   +
 STARTER SEE NOTES
 No connection rewuired for remote start. The vehicle will crank when accessory powers down during start cycle.
 TACH SIGNAL White Ignition module on engine   AC
 This is for the 4 cylinder engine. On the 6 cylinder engine use VIOLET in the same location.
 FUEL INJECTOR Opposite from Pink At any injector on engine   AC
 LOCK White In C1 connector on BCM   -
 One wire system locks with ground (-) and unlocks with a 1.5K resistor to ground (-). The BCM is located with the fusebox on the passenger side of the center console. Connectors run from left to right C1 (72-pin), C2 (72-pin), C3 (40-pin), C4 (not used).
 UNLOCK White In C1 connector on BCM   -
 DOORPIN SEE NOTES
 Gray/black (dr. door), Tan/white (pass door), Lt.blue/black (left rear door) & Lt.GREEN/ black (right rear door). All 4 wires are found at the BCM on the right side of the center console in the large gray plug on the end of the module.
 HOODPIN Pink/black In C1 connector on BCM   -
 TRUNK PIN ORANGE / black In C1 connector on BCM   -
 TRUNK RELEASE BROWN / white In C1 connector on BCM   -
 FACTORY ARM With OEM remote only
 FACTORY DISARM With OEM remote only
 BRAKESWITCH White Brake switch or C1 plug on BCM   +
 PARKLIGHTS Brown In C3 connector on BCM   +
 HAND BRAKE Lt.blue In C1 connector on BCM   -
 HORN Tan In C2 connector on BCM   -
 DRIVER WINDOW UP Dk.blue At switch in driver's door   REV POL
 DRIVER WINDOW DOWN Brown At switch in driver's door   REV POL
 PASSENGER WINDOW UP Lt.blue At switch in driver's door   REV POL
 PASSENGER WINDOW DOWN Tan At switch in driver's door   REV POL
 LEFT REAR WINDOW UP Dk.green At switch in driver's door   REV POL
 LEFT REAR WINDOW DOWN Violet At switch in driver's door   REV POL
 RIGHT REAR WINDOW UP Lt.green At switch in driver's door   REV POL
 RIGHT REAR WINDOW DOWN Violet At switch in driver's door   REV POL
 VSS WIRE Brown driver kick panel (at power interface module)   AC
 TRANSPONDER 12 VOLTS RED / white In black plug on ignition switch   +
 TRANSPONDER DATA Green In black plug on ignition switch   DATA
 PASSLOCK DATA White In 6-pin green plug at ignition switch   DATA
 PASSLOCK GROUND WHITE/ black In 6-pin green plug at ignition switch   -
stuntinonabusa
Member - Posts: 44
Posted: January 25, 2008 at 7:40 AM / IP Logged
thank you kind sir!!!
Friday, May 31, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
