2009 Pontiac Vibe Alarm/Remote Start Wiring
trevor56
Member - Posts: 6
Posted: August 27, 2009 at 11:40 AM / IP Logged
I really need wiring diagram for 2009 pontiac vibe. Attempting to install car alarm. I am trying to locate where the door trigger wire is.
I was told by the dealer that the wiring is different from that of a 2007-2008.
Any help would be nice.
chev104275
Gold - Posts: 1,428
Posted: August 27, 2009 at 4:49 PM / IP Logged
2009 PONTIAC VIBE 4DR SPORT WAGON
Security
WIRE COLOR POLARITY LOCATION
Battery BLUE & RED (+) IGNITION SWITCH HARNESS
Ignition 1 GREEN (+) IGNITION SWITCH HARNESS
Starter 1 WHITE (+) IGNITION SWITCH HARNESS
All Door Trigger GRAY (-) AT MAIN BODY ECU
   TO AVOID DOMELIGHT DELAY USE INDIVIDUAL DOOR TRIGGERS AND DIODE ISOLATE EACH WIRE
LF Latch VIOLET (-) AT MAIN BODY ECU
RF Latch TAN (-) AT MAIN BODY ECU
LR Latch YELLOW (-) AT MAIN BODY ECU
RR Latch BLACK (-) AT MAIN BODY ECU
Trunk Trigger LIGHT GREEN (-) AT MAIN BODY ECU
Alarm Disarm PINK (-) AT MAIN BODY ECU
   A DOUBLE PULSE ON THIS WIRE WILL UNLOCK ALL DOORS
Parking Lights GREEN (+) IN HARNESS IN DRIVER KICKPANEL
Low Crr Pk Lights BROWN (-) AT VEHICLE LIGHT SWITCH
Convenience
Headlights-Lo GREEN (-) AT VEHICLE LIGHT SWITCH
Headlights-Hi LIGHT GREEN (-) AT VEHICLE LIGHT SWITCH
LF Pk Lt Bulb GREEN (+) AT FRONT LEFT PARKING LAMP
RF Pk Lt Bulb GREEN (+) AT FRONT RIGHT PARKING LAMP
LR Pk Lt Bulb GREEN (+) AT REAR LEFT PARKING LAMP
RR Pk Lt Bulb GREEN (+) AT REAR RIGHT PARKING LAMP
All Hazrd Lights TAN (-) AT VEHICLE HAZARD SWITCH
LF Hazrd Bulb YELLOW (+) AT FRONT LEFT TURN LAMP
RF Hazrd Bulb BLUE/RED (+) AT FRONT RIGHT TURN LAMP
LR Hazrd Bulb YELLOW (+) AT REAR LEFT TURN LAMP
RR Hazrd Bulb LIGHT BLUE (+) AT REAR RIGHT TURN LAMP
Wipers-Lo BLACK (+) AT WIPER CONTROL SWITCH
Wipers-Hi RED (+) AT WIPER CONTROL SWITCH
Parking Brake TAN (-) AT VEHICLE PARKING BRAKE SWITCH
   ALSO AT MAIN BODY ECU
Remote Start
Ignition 2 BROWN (+) IGNITION SWITCH HARNESS
Accessory 1 GRAY (+) IGNITION SWITCH HARNESS
Starter 2 BLACK (+) IGNITION SWITCH HARNESS
Anti-Theft Type UNIVERSAL IMMOBILIZER
Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Key Sense BLUE (-) IGNITION SWITCH HARNESS
Tachometer GRAY (AC) AT DATLINK CONNECTOR UNDER DRIVER SIDE DASH
Speed Sense VIOLET (AC) AT ECM MODULE
   ALSO IN RADIO HARNESS
Low Crr. Pk Lights BROWN (-) AT VEHICLE LIGHT SWITCH
Brake Lights BLUE (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Lights RED (+) IN HARNESS BEHIND TRIM IN LEFT SIDE OF CARGO AREA
Horn LIGHT GREEN (-) IN HARNESS AT STEERING COLUMN
IMO LIGHT GREEN (DATA) AT TRANSPONDER ECU BEHIND RADIO
IMI PINK (DATA) AT TRANSPONDER ECU BEHIND RADIO
Rear Defrost TAN
Modules
WIRE LOCATION
Please select another category
Doorlocks/Windows
Power Unlock TAN (-) AT MAIN BODY ECU
PowerLock VIOLET (-) AT MAIN BODY ECU
Driver Mtr Unlock GREEN (REV) IN HARNESS IN DRIVER KICKPANEL TO DOOR
Driver Mtr Lock TAN (REV) IN HARNESS IN DRIVER KICKPANEL TO DOOR
Pas Mtr Unlock GREEN (REV) IN HARNESS IN PASSENGER KICKPANEL TO DOOR
Pas Mtr Lock TAN (REV) IN HARNESS IN PASSENGER KICKPANEL TO DOOR
LF Window Up GREEN (REV) AT MASTER WINDOW CONTROL SWITCH
LF Window Dn YELLOW (REV) AT MASTER WINDOW CONTROL SWITCH
RF Window Up GREEN (REV) AT MASTER WINDOW CONTROL SWITCH
RF Window Dn BROWN (REV) AT MASTER WINDOW CONTROL SWITCH
LR Window Up RED (REV) AT MASTER WINDOW CONTROL SWITCH
LR Window Dn BLUE (REV) AT MASTER WINDOW CONTROL SWITCH
RR Window Up BLACK (REV) AT MASTER WINDOW CONTROL SWITCH
RR Window Dn YELLOW (REV) AT MASTER WINDOW CONTROL SWITCH
Sunroof Open GREEN (-) AT SUNROOF CONTROL SWITCH
Sunroof Close BLUE (-) AT SUNROOF CONTROL SWITCH
trevor56
Member - Posts: 6
Posted: August 27, 2009 at 6:08 PM / IP Logged
Thanks so much. Is the ECU located in the kick panel, driver seat.
flobee4
Silver - Posts: 585
Posted: August 27, 2009 at 8:11 PM / IP Logged
Cut and pasted from Directech for 2009 Vibe, Its a little hard to read but all info is there :)
12 Volts     blue (30A, 2.4L models) (7.5A, all others)     +     ignition switch, pin 7
Starter     black     +     ignition switch, pin 8
Ignition     brown     +     ignition switch, pin 6
Data Bus     (only Canadian models have the immobilizer system)
Can Bus High     lt. green     data     data link connector under driver dash, pin 6
Can Bus Low     white     data     data link connector under driver dash, pin 14
Can Bus Sw     N/A
Power Lock     purple     -     driver kick, white 18 pin plug, pin 16
Also found at the fuse box, middle 18 pin plug, pin 4. This wire is only needed if the door locks do not function when the vehicle is running. All other times just use the factory alarm arm wire.
Power Unlock     beige     -     driver kick, white 18 pin plug, pin 15
Also found at the fuse box, middle 18 pin plug, pin 5. This wire is only needed if the door locks do not function when the vehicle is running. All other times just use the factory alarm disarm wire.
Lock Motor     beige     5 wire     driver kick, white 18 pin plug, pin 8
Also found at the fuse box, middle 18 pin plug, pin 8.
Driver Unlock Motor     green     5 wire     driver kick, white 18 pin plug, pin 17
Also found at the Body ECU, white 26 pin plug, pin 2. The Body ECU is attached to the back of the fuse box.
Passenger Unlock Motor     green     5 wire     driver kick, harness to rear
Also found at the fuse box, middle 18 pin plug, pin 18.
Parking Lights (-)     brown     -     headlight switch
Parking Lights (+)     green     +     dr kick or fuse box, top left 30 pin plug, pin 29
Hazards     beige     -     hazard light switch
Turn Signal (Left)     yellow     +     dr kick or fuse box, top left 30 pin plug, pin 27
Turn Signal (Right)     lt. blue     +     dr kick or fuse box, top left 30 pin plug, pin 28
Headlight     purple     -     Body ECU, white 26 pin plug, pin 3
AutoLights
Left Front Door Trigger     purple     -     fuse box, top left 30 pin plug, pin 21
Right Front Door Trigger     beige     -     fuse box, right 32 pin plug, pin 20
Left Rear Door Trigger     black     -     driver kick, white 13 pin plug, pin 10
Also found at the Body ECU, white 26 pin plug, pin 13. The Body ECU is attached to the back of the fuse box.
Right Rear Door Trigger     yellow     -     fuse box, right 32 pin plug, pin 19
Dome Supervision     gray     -     fuse box, left 6 pin plug, pin 2
Trunk/Hatch Pin     lt. green     -     dr kick or fuse box, top left 30 pin plug, pin 7
Rear Glass Pin     N/A
Hood Pin     N/A
Trunk/Hatch Release     N/A
Trunk Release Motor     N/A
Fuel Door Release     N/A
Power Sliding Door (Left)     N/A
Power Sliding Door (Right)     N/A
Factory Alarm Arm     black     -     driver kick, white 18 pin plug, pin 7
Meter this wire while turning the key in the driver door key cylinder. Also found at the fuse box, middle 18 pin plug, pin 7. This wire will also lock the doors.
Factory Alarm Disarm     pink (double pulse)     -     driver kick, white 18 pin plug, pin 6
Meter this wire while turning the key in the driver door key cylinder. Also found at the Body ECU, white 26 pin plug, pin 14. The Body ECU is attached to the back of the fuse box. This wire will also unlock the doors with a double pulse.
Disarm No Unlock     use keysense
Trunk Alarm Shunt     N/A
Tachometer     gray     ac     data link connector under driver dash, pin 9
Fuel Pump     black     +     dr kick or fuse box, top left 30 pin plug, pin 8
Horn Trigger     lt. green     -     switch or fuse box, top 36 pin plug, pin 28
Memory Seat 1     N/A
Memory Seat 2     N/A
trevor56
Member - Posts: 6
Posted: August 28, 2009 at 10:41 PM / IP Logged
Thanks for all the help.
trevor56
Member - Posts: 6
Posted: August 28, 2009 at 10:44 PM / IP Logged
Does anyone know how to remove the lower dash panels, on a 2009 Vibe/Matrix ? I have tried everything and I can figure how the panels separate.
trevor56
Member - Posts: 6
Posted: August 30, 2009 at 7:38 PM / IP Logged
The job is done. Thanks for all the help.
Thursday, May 23, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
