2006 acrua csx
emerson098
Member - Posts: 14
Posted: September 15, 2009 at 3:50 PM / IP Logged
I there I need wire colour info for a 2006 Acura CSX so I can hardwire a bluetooth unit into it.
Thanks in advance I would look it up at work but im off this week.
tommy...
Gold - Posts: 1,901
Posted: September 15, 2009 at 8:54 PM / IP Logged
BatteryWHITE(+)IGNITION SWITCH HARNESS
2006 acrua csx -- posted image.Ignition 1BLACK / YELLOW(+)IGNITION SWITCH HARNESS
2006 acrua csx -- posted image.Ignition 2BLACK/ RED(+)IGNITION SWITCH HARNESS
2006 acrua csx -- posted image.Accessory 1WHITE/ RED(+)IGNITION SWITCH HARNESS
2006 acrua csx -- posted image.Starter 1BLACK/ WHITE(+)IGNITION SWITCH HARNESS
2006 acrua csx -- posted image.Anti-Theft TypeUNIVERSAL IMMOBILIZER
2006 acrua csx -- posted image.Anti-Theft DescriptTHE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
2006 acrua csx -- posted image.Neutral SafetyLIGHT GREEN(-)AT GEAR SELECTOR SWITCH
2006 acrua csx -- posted image.TachometerBLUE(AC)AT PLUG NEAR VEHICLE BATTERY
2006 acrua csx -- posted image.Speed SenseBLUE/WHITE(AC)AT MODULE TO LEFT OF STEERING COLUMN
2006 acrua csx -- posted image.Parking LightsRED / BLACK(+)IN HARNESS TO RIGHT OF STEERING COLUMN
2006 acrua csx -- posted image.Brake LightsWHITE/ BLUE(+)AT SWITCH ABOVE BRAKE PEDAL
2006 acrua csx -- posted image.Reverse LightsGREEN(+)AT VEHICLE FUSE PANEL
BatteryBLUE/WHITE(+)RADIO HARNESS
2006 acrua csx -- posted image.AccesoryYELLOW/RED(+)RADIO HARNESS
2006 acrua csx -- posted image.GroundBLACK(-)RADIO HARNESS
2006 acrua csx -- posted image.IlluminationRED / BLACK(+)RADIO HARNESS
2006 acrua csx -- posted image.LF Speaker (+)BLUE/GREEN
2006 acrua csx -- posted image.LF Speaker (-)GRAY/BLACK
2006 acrua csx -- posted image.RF Speaker (+)RED / GREEN
2006 acrua csx -- posted image.RF Speaker (-)BROWN / BLACK
2006 acrua csx -- posted image.LR Speaker (+)BLUE / YELLOW
2006 acrua csx -- posted image.LR Speaker (-)GRAY/WHITE
2006 acrua csx -- posted image.RR Speaker (+)RED / YELLOW
2006 acrua csx -- posted image.RR Speaker (-)BROWN / WHITE
M.E.C.P & First-Class
