2002 Dodge Ram Quad 1500
Welcome Guest :)
sundial1
Member -
Posted: June 07, 2002 at 10:01 PM / IP Logged
Hello,
Does anyone have a wiring diagram for a 2002 Dodge Ram Quad Cab 1500? I'd like to install a remote starter and alarm system. Thank you!!
Moderator -
Posted: June 07, 2002 at 11:41 PM / IP Logged
Remote Starter Wiring Colors and Notes |
Function | | | Vehicle Color | Location |
Start: | | | YELLOW | IGNITION SWITCH HARNESS |
Ignition #1: | | | BLUE (16 AWG) | IGNITION SWITCH HARNESS |
Ignition #2: | | | RED | IGNITION SWITCH HARNESS |
Ignition #3: | | | GREEN & ORANGE (2 WIRES) | IGNITION SWITCH HARNESS |
Accessory: | | | BLACK/ WHITE & BLUE (2 WIRES) | IGNITION SWITCH HARNESS |
Brake Light: | | | WHITE/ TAN | AT SWITCH ABOVE BRAKE PEDAL |
Tach Signal: | | | TAN/RED | AT IGNITION COIL |
Parking Lights: | | | PURPLE / YELLOW | HEADLIGHT SWITCH* |
Headlights: | | | PURPLE / YELLOW | HEADLIGHT SWITCH * |
OEM Alarm Disarm: | | | LT. GREEN/ ORANGE ***** | HARNESS COMING IN FROM DRIVER'S DOOR |
OEM Alarm Arm: | | | | |
Diesel Glow Plug: | | | | |
Clutch Bypass Wire: | | | | |
Notes: | | * This Is A Single Wire System. Parking Lights Need To See A Ground (-) Through A 1.4 K-Ohm Resistor. Headlights Need To See A Ground (-) Through A 1.8 K-Ohm Resistor. ** Diesel Vehicles - ORANGE / Black Wait to Start; Tach Wire Is Gray/Black. Both Wires Are Located In A Black Connector Center Top Of Fire Wall. There Are Two Black Connectors, The Correct One Does Not Have A White Insert. |
Alarm and Keyless Entry Wiring Colors and Notes |
Constant +12 Volts: | | | PINK/BLACK | IGNITION SWITCH HARNESS |
Starter Kill: | | | YELLOW | IGNITION SWITCH HARNESS |
Ignition +12 Volts: | | | BLUE (16 AWG) | IGNITION SWITCH HARNESS |
Dome Lights/Superv: | | | SEE NOTE *** | |
OEM Horn: | | | BLACK/ RED (-) | STEERING COLUMN HARNESS |
Power Lock: | | | WHITE/ GREEN | DRIVER'S KICK PANEL **** |
Power Unlock: | | | WHITE/ GREEN | DRIVER'S KICK PANEL **** |
Trunk Release: | | | N/A | |
Alarm Input Wire: | | | SEE NOTE *** | |
Notes: | | *** Separate Triggers For Each Door. The Driver's Door Trigger Is Tan (-). The Left Rear Door Trigger Is Tan/Orange (-). Both Wires Can Be Found In The Driver's Kick Panel. The Passenger Front Door Trigger Is Tan/Red (-) And the Passenger Rear Door Trigger Is Tan / YELLOW (-). Both Of These Wires Can Be Found In The Passenger Kick Panel. Diode Isolate Each Wire For Alarm Trigger With The Bands Facing Away From The Alarm/Remote Start Module. Use Only One Trigger For Dome Light Supervision. **** Single Wire Door Lock System. Lock Requires A Ground (-) Pulse Through A 867 Ohm Resistor. Unlock Requires A Ground (-) Pulse Through A 364 Ohm Resistor. Diode Isolate One Of The Wires. ***** Requires A Negative Pulse Through A 1.5 K-Ohm Resistor |
Thursday, May 23, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
