2012 Toyota Sequoia Alarm/Remote Start/Stereo Wiring
chigl
Member - Posts: 9
Posted: April 21, 2013 at 1:54 PM / IP Logged
Hi All, I am installing a Compustar Remote Start in a 2012 Sequoia Platinum. I am trying to locate a few wires and am looking for any pictures or diagrams that might help. Here's what I am looking for:
1) The blue wire for the mirror defroster located at Pin 19 of the 66 pin white plug at the rear of the DS fuse box.
2) The green wire for the rear defroster located at pin 3 of the 20 pin gray plug in the DS kick panel.
3) For the heated seats: a) The pink wire located at pin 3 or 2 of the black plug for the left seat heater; b) the beige wire located at pin 2 or four of the black 8 or 14 pin plug for the right heater switch.
Any and all help is appreciated!!
Thanks!
chigl
Member - Posts: 9
Posted: April 21, 2013 at 5:02 PM / IP Logged
OK - For #2, I found pin 3 for the Rear defroster connection.
chigl
Member - Posts: 9
Posted: April 21, 2013 at 6:53 PM / IP Logged
I'm also looking for the location of the TPMS module on the passenger side behind the glove box.
chigl
Member - Posts: 9
Posted: April 21, 2013 at 10:26 PM / IP Logged
I found the TPMS module. I'm stilltrying to locate the correct blue wire at Pin 19 of the 66 Pin plug at the fuse box.
chigl
Member - Posts: 9
Posted: April 28, 2013 at 11:33 PM / IP Logged
Hi, I'm looking for a wiring schematic to install a remote start in a 2012 Toyota Sequoia. In particular I am looking for the ignition harness and dash fuse box wiring schematics diagrams or pictures.
Platinum - Posts: 13,674
Posted: April 29, 2013 at 12:08 AM / IP Logged
According to the info you posted, you will have to remove the mounting hardware for the drivers side fusebox and look behind it.
Posted: April 29, 2013 at 1:21 AM / IP Logged
The answer to all your questions, especially ref. ignition wires would be to use a DMM to confirm.
And dropping fuse/body management units in Toyotas isn't difficult, just a 10mm socket with extensions and patience.
wirewise
Moderator - Posts: 489
Posted: June 03, 2013 at 9:43 AM / IP Logged
Some wiring info to add to this post for future reference....
2012 TOYOTA SEQUOIA 4DR SUV WITH 4.6L ENGINE AND 8-SPEAKER AUDIO SYSTEM
Audio/Mobile Video
WIRE COLOR POLARITY LOCATION
Battery BLUE (+) RADIO HARNESS
Accessory GRAY (+) RADIO HARNESS
Ground WHITE/ BLACK (-) RADIO HARNESS
Illumination GREEN (+) RADIO HARNESS
Power Antenna WHITE (+) RADIO HARNESS
LF Speaker (+) YELLOW
   THESE WIRES ALSO GO TO THE FRONT LEFT DASH SPEAKER
LF Speaker (-) WHITE
RF Speaker (+) LIGHT GREEN
   THESE WIRES ALSO GO TO THE FRONT RIGHT DASH SPEAKER
RF Speaker (-) BLUE
LR Speaker (+) RED
   THESE WIRES ALSO GO TO THE REAR LEFT ROOF PILLAR SPEAKER
LR Speaker (-) WHITE
RR Speaker (+) BLACK
   THESE WIRES ALSO GO TO THE REAR RIGHT ROOF PILLAR SPEAKER
RR Speaker (-) YELLOW
Amp Location FOR AMPLIFIER INFORMATION SEE JBL TRIM
Steering Cntrls YES
Speed Cntrl YES
Radio Security YES
Security
Battery WHITE & BLUE (+) IGNITION SWITCH HARNESS
   EACH WIRE IS FUSED AT 7.5 AMPS, GO TO FUSEBOX OR DIRECTLY TO BATTERY FOR HIGH CURRENT APPLICATION
Ignition 1 LIGHT GREEN (+) IGNITION SWITCH HARNESS
Starter 1 GREEN (+) IGNITION SWITCH HARNESS
Domelight Super BLUE (-) AT INTERIOR DOME LIGHT SWITCH ASSEMBLY
LF Latch BROWN (-) MAIN BODY ECU
RF Latch TAN (-) MAIN BODY ECU
LR Latch GREEN (-) UNDER DASH FUSEBOX
   MAY ALSO BE BLACK ON SOME MODELS
RR Latch BLUE (-) MAIN BODY ECU
Trunk Trigger PINK (-) AT REAR DOOR ECU IN REAR DOOR
Alarm Disarm BLACK (-) MAIN BODY ECU
   TEST THIS WIRE WHILE TURNING THE KEY IN THE DRIVER DOOR CYLINDER, USE DOUBLE PULSE TO UNLOCK ALL DOORS
Alarm Arm VIOLET (-) UNDER DASH FUSEBOX
Parking Lights GREEN (+) IN HARNESS IN PASSENGER KICKPANEL
Low Crr Pk Lights TAN (-) AT VEHICLE HEADLIGHT SWITCH
   ALSO AT MAIN BODY ECU
Convenience
Headlights-Lo WHITE (-) AT VEHICLE LIGHT SWITCH
Headlights-Hi VIOLET (-) AT VEHICLE LIGHT SWITCH
LF Pk Lt Bulb VIOLET (+) AT LEFT FRONT PARKING LIGHT
RF Pk Lt Bulb VIOLET (+) AT RIGHT FRONT PARKING LIGHT
LR Pk Lt Bulb GREEN (+) AT LEFT TAIL LIGHT
RR Pk Lt Bulb GREEN (+) AT RIGHT TAIL LIGHT
All Hazrd Lights GRAY (-) AT VEHICLE HAZARD SWTICH
LF Hazrd Bulb RED (+) AT FRONT LEFT TURN LAMP
RF Hazrd Bulb PINK (+) AT FRONT RIGHT TURN LAMP
LR Hazrd Bulb RED (+) AT REAR LEFT TURN LAMP
RR Hazrd Bulb PINK (+) AT REAR RIGHT TURN LAMP
Wipers-Lo LIGHT GREEN (+) AT VEHICLE WIPER SWITCH
Wipers-Hi RED (+) AT VEHICLE WIPER SWITCH
Parking Brake TAN (-) AT VEHICLE PARKING BRAKE SWITCH
Seat Mem 1 PINK (-) AT MEMORY SEAT SWITCH
Seat Mem 2 TAN (-) AT MEMORY SEAT SWITCH
Remote Start
Ignition 2 BLACK (+) IGNITION SWITCH HARNESS
Accessory 1 GRAY (+) IGNITION SWITCH HARNESS
Anti-Theft Type UNIVERSAL IMMOBILIZER
Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Key Sense GRAY (-) IGNITION SWITCH HARNESS
   THIS WIRE WILL ALSO DISARM THE FACTORY ALARM WITHOUT UNLOCKING THE DOORS
Tachometer WHITE (AC) OBDII CONNECTOR
Speed Sense BLACK (AC) AT ECM MODULE ON PASSENGER SIDE FIREWALL
Low Crr. Pk Lights TAN (-) AT VEHICLE HEADLIGHT SWITCH
Brake Lights TAN (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Lights BLUE (+) IN HARNESS IN DRIVERS KICKPANEL TO REAR
Horn TAN (-) IN HARNESS AT STEERING COLUMN
Rear Defrost RED (-) AT A/C AMPLIFIER ASSEMBLY
Modules
WIRE LOCATION
Module 1 MAIN BODY ECU - UNDER DRIVER SIDE OF DASH ATTACHED TO FUSEBOX
Module 2 ABS MODULE - UNDER HOOD ON DRIVER SIDE FIREWALL
Module 3 ECM - UNDER HOOD ON PASSENGER SIDE FIREWALL
Doorlocks/Windows
Power Unlock WHITE (-) UNDER DASH FUSEBOX
PowerLock RED (-) UNDER DASH FUSEBOX
Driver Mtr Unlock WHITE (REV) IN HARNESS IN DRIVER KICKPANEL
Driver Mtr Lock BLUE (REV) IN HARNESS IN DRIVER KICKPANEL
   MAY ALSO BE PINK
LF Window Up TAN (REV) AT WINDOW SWITCH IN DRIVER DOOR
LF Window Dn LIGHT BLUE (REV) AT WINDOW SWITCH IN DRIVER DOOR
RF Window Up GREEN (REV) AT WINDOW SWITCH IN PASSENGER DOOR
RF Window Dn PINK (REV) AT WINDOW SWITCH IN PASSENGER DOOR
LR Window Up VIOLET (REV) AT WINDOW SWITCH IN DRIVER DOOR
LR Window Dn BLACK (REV) AT WINDOW SWITCH IN DRIVER DOOR
RR Window Up TAN (REV) AT WINDOW SWITCH IN DRIVER DOOR
RR Window Dn LIGHT GREEN (REV) AT WINDOW SWITCH IN DRIVER DOOR
Sunroof Open TAN (-) AT SUNROOF CONTROL SWITCH
Sunroof Close VIOLET (-) AT SUNROOF CONTROL SWITCH
2012 TOYOTA SEQUOIA 4DR SUV WITH 5.7L ENGINE AND NAVIGATION EQUIPPED JBLŽ 14-SPEAKER AUDIO SYSTEM
Audio/Mobile Video
Amp Location UNDER RIGHT FRONT SEAT
Steering Cntrls YES
Speed Cntrl YES
Radio Security YES
Security
Convenience
Remote Start
Modules
WIRE LOCATION
Doorlocks/Windows
   MAY ALSO BE PINK
2012 TOYOTA SEQUOIA 4DR SUV WITH 5.7L ENGINE AND JBLŽ 14-SPEAKER AUDIO SYSTEM
Audio/Mobile Video
Steering Cntrls YES
Speed Cntrl YES
Radio Security YES
Security
Convenience
Remote Start
Modules
WIRE LOCATION
Doorlocks/Windows
   MAY ALSO BE PINK
Thursday, May 23, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
