wiring diagram req for delco from 2002 bu
jomlabr
Posted: May 07, 2014 at 8:31 AM / IP Logged
Hi. I've got a Delco CD and radio tuner (Delco part number 16249434) that I pulled from a 2002 Buick. I need to obtain a wiring diagram, so I can install it into a camper.
I've not had much luck with my Google-fu. If you have a wiring diagram for such a beast as this, I'd appreciate it greatly if you would be kind enough to share.
Thank you!
the12volt
Administrator - Posts: 3,955
Posted: May 07, 2014 at 10:00 AM / IP Logged
I'd recommend using a Metra harness to plug into the radio, possibly the 71-2001, but look here for the specific model 2002 Buick the radio was removed from to be sure. https://www.the12volt.com/installbay/appguide.asp?yr=2002&make=Buick
The harness will have conventional wiring colors as shown here: https://www.the12volt.com/request/request2.asp
wiring diagram req for delco from 2002 bu -- posted image. the12volt • Support the12volt.com
Sunday, June 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
