2010 GMC Canyon, Remote Start Wiring
sparxx513
Copper - Posts: 56
Posted: December 30, 2018 at 4:52 PM / IP Logged Link to Post Post Reply Quote sparxx513
Anyone able to provide a wiring print for this one? Will be using a Avital Remote start along with an Idatalink AL-CA for the bypass and data interface. Anyone have any tips for this one? Seems to be a little different from the remote starts ive done.
Thanks in advance guys.
geepherder
Platinum - Posts: 3,668
Posted: December 31, 2018 at 7:52 AM / IP Logged Link to Post Post Reply Quote geepherder
It's listed in the wiring section:
https://www.the12volt.com/installbay/vehiclewiring/1/yeard/GMC.html
https://www.the12volt.com/installbay/forum_posts.asp?tid=118623
sparxx513
Copper - Posts: 56
Posted: January 12, 2019 at 4:19 PM / IP Logged Link to Post Post Reply Quote sparxx513
Just finished this one up. A couple notes of things i found. According to all the wiring prints i found. The +Brake wire is supposed to be Light blue at the brake pedal. This on had no light blue, and had 12v when the brake was not pressed. No wire on the two switches at the pedal had 12v when the pedal was pushed. There is a harness that is used for a trailer connection, trailer brake stored just up and forward of the brake pedal. This one has a light blue wire with 12v when the brake is applied.
Also, for the drivers door trigger there is a gray with black strip wire in the drivers kick.
Tuesday, May 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
