Viper 5706v Remote Start Wiring, 2000 Honda Civic
jdm99prelude
Member - Posts: 9
Posted: November 07, 2022 at 8:17 PM / IP Logged Link to Post Post Reply Quote jdm99prelude
on the 10-pin RS Harness, do the pink(ignition 1 input/output), and orange (accesory output) need to be connected? and to which wire...installing on a 2000 Honda Civic.
geepherder
Platinum - Posts: 3,668
Posted: November 07, 2022 at 10:14 PM / IP Logged Link to Post Post Reply Quote geepherder
Here's a link to the wiring info for your car:
https://www.the12volt.com/installbay/alarmdetail/1054.html
Even if you decide you don't want to use the remote start, you should at least connect the ignition 1 wire as it's used for sensing key position. This is used when you enter valet mode with the key, or to trigger the alarm if someone attempts to start without disarming first.
Accessory is used to power the heating and air conditioning which is why many people use remote start.
jdm99prelude
Member - Posts: 9
Posted: November 08, 2022 at 1:20 PM / IP Logged Link to Post Post Reply Quote jdm99prelude
thanks for the wiring diagram, the wire for the accessory is blk/yellow if somebody wanna update it, so do i connect those wires with the red/blk (fused 12v acc wire) and red (ignition 1 wire)on the remote start harness also? so the only wires i dont use on it is:
PINK/BLACK (+) FLEX RELAY INPUT #87a key side (if required) of FLEX RELAY
PINK/WHITE (+) IGNITION 2 / FLEX RELAY OUTPUT #30 of FLEX RELAY
geepherder
Posted: November 08, 2022 at 8:56 PM / IP Logged Link to Post Post Reply Quote geepherder
The Viper red wires in the remote start harness are constant power and do not get connected to your vehicle's ignition and accessory wires. It can look misleading in the manual. They are the supply for the built in ignition and accessory relays.
The pink connects to your vehicle's ignition wire and the orange (IIRC) connects to your vehicle's accessory wire.
jdm99prelude
Member - Posts: 9
Posted: November 09, 2022 at 12:15 PM / IP Logged Link to Post Post Reply Quote jdm99prelude
so do i tie all the RED together for 12v constant, and all PINk to ignition 1 and dont need ignition 2 wire and ORANGE to accessory? OR do i just go what the manual says which is
Remote Start, White 10-pin heavy gauge connector
1 NC No Connection
2 RED/BLACK (+) FUSED 12V ACCESSORY/STARTER INPUT
3 PINK/BLACK (+) FLEX RELAY INPUT #87a key side (if required) of FLEX RELAY
4 PINK/WHITE (+) IGNITION 2 / FLEX RELAY OUTPUT #30 of FLEX RELAY
5 RED (+) FUSED 12V IGNITION 1 INPUT
6 GREEN (+) STARTER INPUT (KEY SIDE OF THE STARTER DISABLE)
7 VIOLET (+) STARTER OUTPUT (CAR SIDE OF THE STARTER DISABLE)
8 ORANGE (+) ACCESSORY OUTPUT
9 RED/WHITE (+) FUSED 12V IGNITION 2 / FLEX RELAY INPUT 87
10 PINK (+) IGNITION 1 INPUT/OUTPUT
or do i pair it like this...
geepherder
Posted: November 09, 2022 at 7:25 PM / IP Logged Link to Post Post Reply Quote geepherder
All the reds in the remote start harness (red, red/black and red/white) with fuses connect to constant power. Pink is ignition 1. If you don't have an ignition 2 or accessory 2 the pink/white wire will not be used. Orange will connect to your accessory wire.
Sunday, June 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
