1997 toyota camry
skiflyer45
Member - Posts: 33
Posted: February 21, 2004 at 1:00 PM / IP Logged
Hi,
can anyone provide me with a wiring diagram for a 97 toyota camry. I need it for a keyless entry/ALARM install.
Thanks in advance
---Alex---
boomer_106
Silver - Posts: 710
Posted: February 23, 2004 at 8:29 PM / IP Logged
Here ya go Alex
Toyota
Camry
1997-2001
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
RED
IGNITION SWITCH HARNESS **
Ignition  #1:
BLACK/ RED
Ignition #2:
BLACK / YELLOW
Ignition  #3:
N/A
Accessory:
BLUE/RED
Brake  Light:
GREEN / WHITE
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
BLACK ORANGE
AT ECM OR IGNITOR *
Parking Lights:
GREEN (+)
AT # PIN WHITE CONN. AT FUSE PANEL
Headlights:
RED / YELLOW (-)
AT HEADLIGHT SWITCH
OEM Alarm  Disarm:
RED / GREEN (-)
# PIN CONN IN DRIVER'S KICK PANEL
OEM Alarm  Arm:
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * ECM Is Located Behind The Glove Box. ** Beginning in 1998, this vehicle is equipped with a transponder type of theft system. See Installation Note #144 - Bypassing Transponder Theft Systems.
Toyota
Camry
1997-2001
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
WHITE/ RED & WHITE
Starter  Kill:
RED
Ignition  +12 Volts:
BLACK/ RED
Dome  Lights/Superv:
RED / WHITE (-)
7 PIN WHITE CONN. ABOVE FUSE PANEL
OEM Horn:
GREEN/ BLACK (-)
IN STEERING COLUMN HARNESS
Power  Lock:
LIGHT GREEN (-)
# PIN CONN IN DRIVER'S KICK PANEL ***
Power  Unlock:
DARK GREEN (-)
Trunk  Release:
N/A
Alarm  Input Wire:
RED / WHITE (-)
Notes:
** Child Safety Wire is BLUE/RED (-) in same connector as door locks. See Note # 209 - Child Safety Door Lock Diagram.
