2002 Buick Century Alarm/Remote Start Wiring
malucyk
Copper - Posts: 56
Posted: October 15, 2002 at 4:56 PM / IP Logged
Anoyone have a wiring diagram for a 2002 Buick Century???
Matthew
Montrealler
Copper - Posts: 155
Posted: October 15, 2002 at 6:28 PM / IP Logged
       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|red                 |+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|pink                |+  |ignition harness            |
|  SECOND IGNITION|white or green      |+  |ignition harness            |
|        ACCESSORY|orange              |+  |ignition harness            |
|       POWER LOCK|RED / black           |-  |drivers kick or BCM *2      |
|     POWER UNLOCK|ORANGE / black        |-  |drivers kick or BCM *2      |
|       LOCK MOTOR|gray                |   |drivers kick panel          |
|     UNLOCK MOTOR|tan                 |   |drivers kick panel          |
|    DISARM DEFEAT|tan                 |   |passengers kick panel       |
| PARKING LIGHTS +|lt. blue            |   |at switch *1                |
|       HEADLIGHTS|yellow              |-  |at switch                   |
|     DOOR TRIGGER|dark blue/white     |-  |drivers kick or BCM *2      |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|ORANGE / black        |-  |light in trunk or BCM *2    |
|TRNK/HTCH RELEASE|brown               |-  |BCM *2                      |
|       TACHOMETER|pur/wht or white    |   |ignition control module     |
|      SPEED SENSE|GREEN / WHITE         |   |ECM under hood *3           |
|       BRAKE WIRE|white               |+  |brake pedal switch          |
|     HORN TRIGGER|black               |-  |steering column             |
|           WIPERS|                    |   |                            |
|  LF WINDOW UP/DN|blue - brown        |A  |drivers door switch         |
|  RF WINDOW UP/DN|lt blue - tan       |A  |drivers switch or kick panel|
|  LR WINDOW UP/DN|green - purple      |A  |drivers switch or kick panel|
|  RR WINDOW UP/DN|lt green - purple   |A  |drivers switch or kick panel|
Notes:
NOTE: This vehicle is equipped with PASS-Key II (VATS). When installing a remote start, refer to directfax document #1049 for bypass wiring.  *1 Larger of the two at the light switch. Can also find BROWN / white in the passenger kick panel in the harness to the rear.  *2 BCM is to the left of the steering column  *3 ECM is in the air cleaner assembly.
Yes I'm Back 2006...
Friday, March 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
