'99 Tiburon
bddego321
Member - Posts: 14
Posted: October 16, 2002 at 11:03 AM / IP Logged
I was just wondering if anyone could help me figure out a way to find the wiring diagrams for my 1999 hyundai tiburon.  I am currently installing a remote starter/alarm, and cant seem to figure out some of the wiring.
Platinum - Posts: 12,488
Posted: October 17, 2002 at 5:18 AM / IP Logged
|              12V|blue/red            |+  |ignition harness            |
|          STARTER|BLACK/ white         |+  |ignition harness            |
|         IGNITION|BLACK/ white         |+  |ignition harness            |
|        ACCESSORY|lt blue/blue        |+  |ignition harness            |
| SECOND ACCESSORY|blue/black          |+  |ignition harness            |
|       POWER LOCK|add actuator        |   |in drivers door             |
|     POWER UNLOCK|same                |   |                            |
| PARKING LIGHTS +|GREEN / WHITE         |   |drivers kick panel          |
| PARKING LIGHTS -|red                 |   |steering column             |
|       HEADLIGHTS|blue/black          |-  |steering column             |
|     DOOR TRIGGER|BLACK/ white         |-  |instrument cluster *1       |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|brown               |-  |cluster or trunk light      |
|       TACHOMETER|yellow or brown     |   |ignition coils *2           |
|      SPEED SENSE|yellow              |   |ECM *3                      |
|       BRAKE WIRE|green               |+  |brake switch                |
|     HORN TRIGGER|GREEN/ red           |-  |steering column             |
|           WIPERS|RED / wht             |-  |steering column             |
|  LF WINDOW UP/DN|blu/wht - blk/yel   |A  |drivers door switch         |
|  RF WINDOW UP/DN|blu/wht - blk/yel   |A  |passengers door switch      |
Notes:
*1 Also found lt blue/blue at either door switch.  *2 Also found white at ECM under driver side dash, in pin 47.  *3 VSS is in pin 42 at ECM under driver side dash.
bddego321
Member - Posts: 14
Posted: October 17, 2002 at 6:55 AM / IP Logged
thanks alot jeff!
bddego321
Member - Posts: 14
Posted: October 17, 2002 at 7:10 AM / IP Logged
uh oh...one problem....in my ignition harness, there is a red wire, a black wire, a yellow wire, and an orange wire.  Then there is a smaller guage white wire with a blue stripe.  These wires dont seem to match up with the wire diagram...
im not too sure what to do about this...please help if you can...thanks.
anthony
Posted: October 17, 2002 at 6:36 PM / IP Logged
are there any of the other main ignition wires in the bunch ?? There will be alot of other wires that you will not use in the ignition harness.
bddego321
Member - Posts: 14
Posted: October 17, 2002 at 6:42 PM / IP Logged
i figured out that part, but now my new problem is that the alarm will not stop sounding unless i disconnect it...im not sure if maybe i wired it wrong...i double checked and it all seemed right...i dont know what to do to make it stop sounding when i connect it....the buttons dont astop it...
Posted: October 17, 2002 at 8:58 PM / IP Logged
Double check the SIREN output of the alarm to the siren. The Siren should be grounded and the (+) wire from the siren should go the the siren output of the alarm system. What kind of system are you installing ?
bddego321
Member - Posts: 14
Posted: October 17, 2002 at 9:32 PM / IP Logged
im installing the commando rscombo
anthony
Posted: October 20, 2002 at 12:04 PM / IP Logged
Did you check to see if the BROWN wire has a (-) current through it ? Make sure of this and post your results.
Friday, March 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
