DIRECTWIRE™ WIRING INFORMATION - FORD / RANGER / 2005 / Remote Start
12volts yellow (x3)(common 40A) + ignition harness
Starter RED / lt. blue + ignition harness
Second Starter N/A
Ignition lt. GREEN/ purple + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory gray / YELLOW + ignition harness
Second Accessory BLACK/ lt. green + ignition harness
Keysense BLACK/ pink - ignition harness
Power Lock pink / YELLOW - SJB, large black plug, pin 5
Notes: The SJB (Smart Junction Box) is the fuse/relay box in the passenger kick panel.
Power Unlock pink/lt. green - SJB, large black plug, pin 9
The SJB in this vehicle shuts down after the doors have been locked for a certain time period, to wake up the system refer to DirectFax document 1093.
Lock Motor red 5wi SJB, gray plug, pin 9
Unlock Motor lt. blue 5wi SJB, large black plug, pin 7
Parking Lights+ brown + SJB, brown plug, pin 8
Parking Lights- WHITE/ black - switch or SJB, sml blk plug, pin 16
Hazards same as turn signal wires
Turn Signal(L) lt grn/wht (F), lt grn/org (R) + turn signal switch
Turn Signal(R) wht/lt blu (F), org/lt blu (R) + turn signal switch
Reverse Light BLACK/ pink + driver kick, harness to rear
Door Trigger yellow/black (D), gray/red (P) - SJB
Notes: The driver door trigger is yellow/black in the large black plug, pin 6. The passenger door(s) trigger is gray/red in the small black plug, pin 3. Use both wires and diode isolate each from each other and the control module. Refer to DirectFax document 1076 for wiring information.
Dome Supervision BLACK/ lt. blue + SJB, gray plug, pin 14
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm N/A
Factory Alarm Disarm N/A
Disarm No Unlock N/A
Tachometer tan / YELLOW ac PCM, pin 48
Notes: The PCM (Powertrain Control Module) is on the passenger side firewall, under the hood.
For tach, can also go to the ignition coil pack or any fuel injector and use the wire that is NOT red.
Wait to start N/A
Brake Wire lt. green + brake pedal switch
Parking Brake RED / yellow - switch or SJB, lrg blk plug, pin 17
Horn Trigger yellow/lt. green to dk. blue - switch or SJB, sml blk plug, pin 18
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
SecuriLock
Part #: 556SW
Alternate Part1 #: 556UW
Alternate Part2 #: 555U
Notes: Standard on all models.
Be careful whose advice you buy, but be patient with those who supply it.
