2002 Ford Windstar Alarm/Remote Start Wiring
Welcome Guest :)
Scott105
Member -
Posted: May 05, 2002 at 4:41 PM / IP Logged
do you happen to have the wiring diagram for this vehicle. It will glady be appreciated.
Moderator -
Posted: May 05, 2002 at 9:05 PM / IP Logged
Remote Starter Wiring Colors and Notes |
Function | | | Vehicle Color | Location |
Start: | | | DK. GREEN | IGNITION SWITCH HARNESS * |
Ignition #1: | | | WHITE/ YELLOW | IGNITION SWITCH HARNESS |
Ignition #2: | | | BLACK | IGNITION SWITCH HARNESS |
Ignition #3: | | | VIOLET/ORANGE | IGNITION SWITCH HANRESS ** |
Accessory: | | | BLACK/ LT. GREEN | IGNITION SWITCH HARNESS |
Brake Light: | | | RED / LT. GREEN | AT SWITCH ABOVE BRAKE PEDAL |
Tach Signal: | | | DK. BLUE/LT. GREEN | AT COIL MODULE *** |
Parking Lights: | | | YELLOW/LT. BLUE (-) | AT FRONT ELECTRONIC MODULE **** |
Headlights: | | | | |
OEM Alarm Disarm: | | | LT. BLUE/BLACK (-) | 16. PIN CONN. LEFT OF STEERING COLUMN |
OEM Alarm Arm: | | | ARMS WHENEVER THE DOORS | ARE LOCKED. |
Diesel Glow Plug: | | | | |
Clutch Bypass Wire: | | | | |
Notes: | | * These Vehicles May Be Equipped With Ford's PATS Anti-Theft System. Bypassing Transponder Theft Systems. ** Use Ignition #3 to Drive a Relay and Fuse the Constant +12 Volts of the Relay Seperately at Battery With a Separate 30 Amp Fuse. *** Located Top Left Side Of The Engine |
Alarm and Keyless Entry Wiring Colors and Notes |
Constant +12 Volts: | | | RED | IGNITION SWITCH HARNESS |
Starter Kill: | | | DK. GREEN | IGNITION SWITCH HARNESS * |
Ignition +12 Volts: | | | WHITE/ YELLOW | IGNITION SWITCH HARNESS |
Dome Lights/Superv: | | | ORANGE / WHITE (-) | AT FRONT ELECTRONIC MODULE **** |
OEM Horn: | | | DK. GREEN/ ORANGE (-) | 8 PIN CONN. LEFT OF STEERING COLUMN |
Power Lock: | | | LT. BLUE/ORANGE (-) | 16 PIN CONN. IN DRIVER'S KICK PANEL |
Power Unlock: | | | LT. GREEN/ YELLOW (-) | 16 PIN CONN. IN DRIVER'S KICK PANEL |
Trunk Release: | | | SEE NOTE ***** | |
Alarm Input Wire: | | | ORANGE / WHITE (-) | AT FRONT ELECTRONIC MODULE **** |
Notes: | | **** Located Behind Driver Side Dash Left Of Steering Column. ***** Sliding Door Operation Tan/Lt. Blue (-) At Switch (Same Color For Driver or Passenger Side). |
Fruhead
Member -
Posted: January 07, 2003 at 9:24 AM / IP Logged
I'm going to be installing a remote start in one of these vans. I have a 555U transponder unit, and was wondering if this would bypass ford's anti-theft system.
Thanks!
Moderator -
Posted: January 07, 2003 at 9:30 AM / IP Logged
Yes it will.
Saturday, June 8, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
