’04 Nissan Xterra Alarm Wiring
j68rh
Copper - Posts: 147
Posted: August 19, 2005 at 9:57 AM / IP Logged
Hey I have a commando FM-870 alarm that was given to me and I would like the wiring diagram so I can hook it up.  Also i have 2 other outputs so how would I hook it up to roll down my windows and roll them up
thepencil
Gold - Posts: 1,526
Posted: August 19, 2005 at 10:21 AM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - NISSAN / XTERRA / 2004 / Remote Start
12volts green (40A)   +   ignition harness
Starter BLACK / YELLOW   +   ignition harness
Second Starter GREEN/ YELLOW   +   ignition harness
Ignition BLACK/ white   +   ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory RED / yellow   +   ignition harness
Second Accessory WHITE/ blue   +   ignition harness
Keysense WHITE/ green   +   ignition harness
Power Lock lt. GREEN/ red   -   SECU to right of column, pin 5
Power Unlock brown   -   SECU to right of column, pin 4
Lock Motor blue   5wi SECU to right of column, pin 54
Unlock Motor GREEN / WHITE   5wi SECU to right of column, pin 55
Parking Lights+ blue/red   +   headlight switch
Parking Lights- N/A
Hazards same as turn signal wires
Turn Signal(L) GREEN/ YELLOW   +   steering column
Turn Signal(R) GREEN/ red   +   steering column
Reverse Light yellow/red   +   passenger kick, harness to rear
Door Trigger see notes   -   SECU to right of column
Notes: Vehicles without power door locks, the door trigger/dome light is RED / black in the driver kick, harness to rear.
Vehicles with power door locks, the driver door is GREEN/ red at the SECU, pin 1, the front passenger door is GREEN/ black at the SECU, pin 2, and the rear doors are RED / black at the SECU, pin 3. Use all three wires and diode isolate each.
Dome Supervision RED / black   -   SECU to right of column, pin 31
Trunk/Hatch Pin common with rear door trigger
Hood Pin BLACK/ pink   -   SECU to right of column, pin 6
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm yellow   -   SECU to right of column, pin 11
Factory Alarm Disarm yellow/red   -   SECU to right of column, pin 10
Disarm No Unlock see factory alarm disarm
Tachometer pink/blue   ac   instrument cluster or ECM, pin 3
Notes: The ECM is located below the heater box to the right of the accelerator pedal, behind trim panel. The tach is in the top row, 2nd pin left of center of the plug.
Wait to start N/A
Brake Wire BROWN / red   +   brake pedal switch
Parking Brake yellow   -   parking brake switch
Horn Trigger lt. GREEN/ red   -   steering column
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
No Type:
N/A
Part #: N/A
Notes:
DIRECTWIRE™ WIRING INFORMATION - NISSAN / XTERRA / 2004 / Accessory
Parking Lights- N/A
Headlight red (L), RED / black (R)   +   headlight switch
Speed Sense GREEN/ black      instrument cluster or ECM, pin 29
Notes: The ECM is located below the heater box to the right of the accelerator pedal, behind trim panel. The VSS is in the 2nd row from the top, 4th pin right of center of the plug.
Wipers WHITE/ red (L), blue/white (H)   -   steering column
LF Window up/dn blue - blue/black   A   driver window switch in door
RF Window up/dn blue / YELLOW - blue/white   A   driver kick, door harness
LR Window up/dn GREEN/ YELLOW - GREEN/ red   A   driver kick, door harness
RR Window up/dn GREEN/ black - GREEN / WHITE   A   driver kick, door harness
Sun Roof open/close N/A
Sun Roof Limit/close N/A
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
No Type:
N/A
Part #: N/A
Notes:
Be careful whose advice you buy, but be patient with those who supply it.’04 Nissan Xterra Alarm Wiring -- posted image.
j68rh
Copper - Posts: 147
Posted: August 19, 2005 at 12:50 PM / IP Logged
what does  SECU mean and where is it located at?
mo12v
Posted: August 19, 2005 at 2:16 PM / IP Logged
SECU = Smart Entrance Control Unit
As instructions say......."SECU to right of column "
MO
thepencil
Gold - Posts: 1,526
Posted: August 19, 2005 at 2:54 PM / IP Logged
Look for a square box.
j68rh
Copper - Posts: 147
Posted: August 19, 2005 at 3:30 PM / IP Logged
the smart entrance control unit is to the right of what column?
Saturday, June 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
