2003 Mazda 6 Remote Start Wiring Diagram
Sick64LBC19st
Posted: August 24, 2005 at 11:37 PM / IP Logged
12volts      black (40A), BLACK/ yel (30A)       +       ignition harness
Starter      BLACK/ blue       +       ignition harness
Second Starter      N/A
Ignition      blue       +       ignition harness
Second Ignition      N/A
Third Ignition      N/A
Accessory      BLACK/ red       +       ignition harness
Second Accessory      BLACK/ white       +       ignition harness
Keysense      WHITE/ blue       +       ignition harness
Notes: Using the status output from the remote start to trigger this wire will disarm the factory alarm without unlocking the doors.
Power Lock      lt. green       -       driver kick or door lock module
Notes: Lock is negative trigger thru a 1.4K ohm resistor. Unlock is a straight negative trigger. MUST use relays.
The door lock control module is located above the passenger kick panel.
Power Unlock      same as power lock wire
Lock Motor      RED / blue       5wi      driver kick or door lock module
Notes: The door lock control module is located above the passenger kick panel.
Unlock Motor      RED / green       5wi      driver kick or door lock module
Parking Lights+      lt. GREEN/ black       +       driver kick, 14 pin plug
Parking Lights-      RED / white       -       headlight switch
Hazards      blue/orange       -       switch or door lock module
Turn Signal(L)      WHITE/ black       +       turn signal switch
Turn Signal(R)      WHITE/ red       +       turn signal switch
Reverse Light      RED / yellow       +       driver kick, 14 pin plug
Door Trigger      GREEN/ orange       -       driver kick or door lock module
Dome Supervision      yellow/black       -       driver kick or door lock module
Trunk/Hatch Pin      brown       -       driver kick or door lock module
Hood Pin      gray/red       -       pin switch or theft module
Notes: The theft-deterrent control module is located in the center console.
Trunk/Hatch Release      yellow       -       switch or door lock module
Power Sliding Door      N/A
Factory Alarm Arm      blue       -       driver kick or door lock module
Notes: Arm is negative trigger thru a 1.4K ohm resistor. Disarm is a straight negative trigger. MUST use relays.
Factory Alarm Disarm      same as factory alarm arm wire
Disarm No Unlock      use key sense wire
Tachometer      NOT blk/wht or grn/stripe       ac       any ignition coil or coil pack
Notes: On the 4 cyl models use the wire that is NOT BLACK/ white. On the 6 cyl models use the wire that is NOT GREEN/ stripe.
Wait to start      N/A
Brake Wire      green       +       brake pedal switch
Parking Brake      brown       -       parking brake switch
Horn Trigger      PURPLE / white       -       switch or door lock module
Memory Seat 1      N/A
Memory Seat 2      N/A
Memory Seat 3      N/A
Interface Module:      Category:
Immobilizer Bypass      Required:
Yes      Type:
Transponder
Part #: 556UW
Alternate Part1 #: 555U
Alternate Part2 #: DesignTech 20402
Alternate Part3 #: DesignTech 29402
Notes:
Door Lock Interface      Required:
Yes      Type:
Multiplex
Part #: 456LW
Notes:12volts      black (40A), BLACK/ yel (30A)       +       ignition harness
I hope this helps...
                    - Mark -
Why keep it stock when you can CUSTOMIZE IT!!!
Saturday, June 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
